Previous in Forum: solar energy for Agl. bore wells   Next in Forum: Understanding Resistor Limits
DC- AC voltage
09/12/2007 12:10 PM
when i want to change voltage any coil from AC to DC, how i can calculate the DC current.
I have acoil with following specefecation
220vac / 60Hz
what happen if i supply the coil by
220vac / 50 Hz
best regardes
Re: DC- AC voltage
09/12/2007 12:43 PM
Any effect will be on the motors or application of the power running thru the coil.
Re: DC- AC voltage
09/12/2007 1:08 PM
Are you asking2 Questions?
  1. AC>DC Coil Volt/Current: If the Coil winding is for AC-and it works well at Vac,then you need a lot less volts DC .You need to find out. This assumes a Contactor Electromagnet.
  2. AC 60hz to50HZ-both220V: ARE You talking of a motor? WILL RUN -SLOWER
Re: DC- AC voltage
09/12/2007 1:45 PM
I am talking about contacore coiland exactly iwant to know if the coil will be damege.
Good Answers: 804
Re: DC- AC voltage
09/12/2007 2:26 PM
Well, you asked a confusing question. What does 50Hz vs 60Hz have to do with AC vs DC? I fail to see the connection there.
If you have an AC coil wound for 50Hz, and you apply 60Hz to it, it will saturate and overheat, eventually burning up. If you have a coil wound for 60Hz and you apply 50Hz to it, it will not provide the same pulling force and likely be too weak for your relay or contactor or solenoid (you didn't specify). If it is too weak to pull in all together, it will also burn up.
But the earlier question about what you are controlling with that coil is still very valid. There are a lot more potential problems than just the coil.
Re: DC- AC voltage
09/12/2007 3:44 PM
if it is a motor then in changing frequency it wil run slower or faster...if 50 Hz i it wil b slower than 60hzs
n in case of coil i dont think thet it wil cause any effect bcoz coil donot hav the frequency specification...it only has voltage specification
Re: DC- AC voltage
09/12/2007 4:50 PM
If you want to calculate the current running through a DC coil use Ohm's Law. If you want the current in an AC coil use the formula for Impedence 'Z'. If the inductive reactance equals the capacitive reactance you're left with the DC resistance of the coil.
An EXPERT is a 'has been', that is a drip under pressure - My Boss
Re: DC- AC voltage
09/13/2007 8:53 AM
Hi,
I think this article is useful for you.
BEST REGARDS
MSJ
Using AC Coils on DC Power
By John DeDad
Oct 1, 2000 12:00 PM
Here's an alternative to rewinding AC coils for operation on DC circuits. It's relatively simple - all it takes are a few calculations and a little bench testing.
Want to skip the time and expense of rewinding AC coils so they can operate on DC? Or are you wondering if it's even possible to use AC coils on DC circuits? If you answered "yes" to both of these questions, there is a method you can use.
Remember, a holding coil, or solenoid, is simply a current-operated device. The device doesn't care what voltage (AC or DC) you apply to it as long as the applied voltage level doesn't exceed the voltage rating of the coil's magnet wire insulation. You can apply a DC voltage to an AC coil. Here's how to go about it:
• First, apply a DC test voltage to the AC coil you want to use, until you draw the same magnitude of operating (holding) current as when the coil operates on AC.
• Then, while applying this DC voltage, insert a fixed but adjustable resistance to get the desired coil dropout characteristics.
There is one important thing to consider here: Make sure you use a bridge that's vastly oversized, so it can withstand the heat generated and any transient overvoltages that may occur. Generally, you can use a 1000PRV bridge on a 120V circuit, but you should use one having a rating about four times the coil's rated current.
The DC voltage noted above usually will be within 30% of the AC voltage. The DC resistance noted in the second bullet usually will be in the same range (30%) of the AC resistance. The DC pickup voltage also will be in this same range of the AC pick-up voltage. However, the DC drop-out voltage will be within 10% of the AC drop-out voltage.
Are there any benefits (aside from saved rewinding costs) by using AC coils on DC circuits? You bet! You can expect up to three times the extended coil life. That's due to the approximate 70% power reduction. By using AC coils on DC circuits, you can expect clean, solid make-and-break operation with no contact chatter, hum, or buzz. Let's go through the procedure in detail. The conversion procedure is simple. All you have to do is follow these four steps.
Step 1: Take some measurements. First, measure the AC current drawn by the specific coil at rated AC voltage. Then, measure the coil's AC pick-up and drop-out voltages. Finally, measure its DC resistance.
Step 2: Do some calculations. First, calculate the coil's AC impedance (Z subscript AC). You do this by dividing the coil's AC voltage (E subscript AC) by its AC current draw (I subscript AC), or
Z subscript AC = E subscript AC/I subscript AC (equation 1).
Then, calculate the coil's AC power (P subscript AC). You do this by multiplying the coil's AC voltage (E subscript AC) by its AC current draw (I subscript AC), or
P subscript AC = E subscript AC x I subscript AC (equation 2).
Step 3: Do some bench testing. Gradually apply a DC voltage to the coil until you see a DC current (I subscript DC ) having the same magnitude as the AC current (I subscript AC) measured in Step 1. Then, measure the DC pick-up and drop-out voltages.
Step 4: Do some more calculations. First, calculate the coil's DC resistance (R subscript DC) by using the following equation:
R subscript DC = E subscript DC x I subscript AC (equation 3).
Then, calculate the coil's DC power, in watts, (P subscript DC) using the following equation:
P subscript DC = E subscript DC x I subscript AC (equation 4).
Verify that the power is 530% of the coil's AC power (P subscript AC) calculated in Step 2.
You may wonder why we're using AC current in equation 3 and equation 4. Our original premise for using AC coils on DC circuits: Apply a DC test voltage until you draw the same magnitude of holding current as when the coil operates on AC. In other words, I subscript AC equals I subscript DC. So, we can insert the measured AC holding current value in these two equations.
Finally, calculate the power factor (PF) by dividing the coil's DC power (P subscript DC) by its AC power (P subscript AC), or
PF4P subscript DC3P subscript AC (equation 5).
Let's try a sample conversion. Suppose you have a signal relay with a coil rated at 120VAC. You measure the DC resistance (2000 ohms) and note the nameplate says AC power is 2VA. The relay contacts are 10A, coin-silver.
Step 1. You can measure the AC current draw (I subscript AC), calculate it using the above data, or do it both ways as a check. By using equation 2, but solving for current draw, you have:
I subscript AC = P subscript AC/E subscript AC = 2VA/120V = 0.017A.
Now, verify that this is close to what you're measuring.
Step 2. Calculate the coil's AC impedance (Z subscript AC) by using equation 1:
Z subscript AC = E subscript AC/I subscript AC = 120V/0.017A = 7059 ohms.
You don't have to calculate the coil's AC power because it's on the nameplate (2VA).
Step 3. Do some bench testing to find the DC voltage that generates the same magnitude of current as when the coil operates on AC. You can also calculate the coil's DC voltage by using equation 3, but solving for E subscript DC:
E subscript DC4R subscript DC= = I subscript AC = 2000 ohms x 0.017A = 34V.
By measuring and doing the calculation, you get a good sense that the DC voltage falls within the prescribed range.
Step 4. You measured the DC coil resistance (2000 ohms, remember?) so you already have this information. But, you need to calculate the coil's DC power (P subscript DC) by using equation 4:
P subscript DC = E subscript DC x I subscript AC = 34V x 0.017A = 0.578W.
This is almost 29% of the AC power (2VA), which is within the prescribed range.
Finally, calculate the coil power factor (PF) by using equation 5:
PF = P subscript DC/P subscript AC = 0.578W/2VA = 0.289 or 28.9%.
That's all there is to it! Thanks to Roger D. Hoestenbach, former Senior Consulting Engineer, Paragon Engineering Services, Inc., Houston, who provided the details for this unique application and procedure.
Register to Reply 7 comments
aladawi1 (1); dadw5boys (1); JRaef (1); m.s.j (1); mixit (1); MUKULMAHANT (1); tanusree (1)
