Previous in Forum: DC- AC voltage   Next in Forum: have you.....?
22 comments
Understanding Resistor Limits
09/12/2007 4:51 PM
Those small resistors that only use about .6 of a Watt dissapation, are they capable of being inserted in 5 amp up to 10 amp lines without suffering any damage?
Re: Understanding Resistor Limits
09/12/2007 5:49 PM
It depends on their resistance ..
Power dissipated in the resistor is I^2 R.... so they would need to be very very low R values to avoid burning out.....
At 5amps... I^2 is 25 therforr for 0.6w dissipation the resistor would have to be 0.6/25 ohms which is stupidly small.
So the short answer is NO.....
09/12/2007 6:07 PM
thanks, but your answer doesn't make much sense to me.
if you were to say, 0.6 = I²R and R = 1 ohm, then the max current would be 0.6 *0.6 =0.36... So I guess that when one speaks of dissapation factors, one speaks of maximum power handling capability. It's a valuable question to me, and all the other folk who like things simplified.
09/12/2007 6:52 PM
How about this?
At 10 amps, you need the following size resistors:
for 1 Ω, 100w
for 10 Ω, 1,000w
for 100 Ω, 10,000w
for 1kΩ, 100,000w
for 10kΩ, 1,000,000w
for 100kΩ, 10,000,000w
At 0.6 watts, you can accommodate the following currents:
for 1 Ω, .77A
for 10 Ω, .24A
for 100 Ω, 77mA
for 1kΩ, 24mA
for 10kΩ, 7.7mA
for 100kΩ, 2.4mA
Does that help?
09/12/2007 8:47 PM
Thanks, but I think its better to underwork your resistors.
Good Answers: 120
09/12/2007 11:24 PM
I have an exercise gym for my resistors. You can build a puny 1/4W runt to a 5000W bully over a short period if they stick to their diet...
Per Ardua Ad Astra
09/13/2007 12:40 AM
LMAO got to go to the WC
Good Answers: 18
09/13/2007 7:48 AM
Ditto!
09/13/2007 2:05 AM
Gees, post 5 & 6 are a waste of ink. obviously intellectual heavy weights:? Now thats the real joke!
09/13/2007 10:03 AM
No doubt. In my work, 50% derating is standard. But that wasn't the question.
09/13/2007 8:28 PM
09/13/2007 2:37 AM
If 0.6= I2 x 1 Then I is the square root of 0.6
This is basic maths.
09/13/2007 4:49 AM
no del, thats wrong. its 0.6 = I² or I² x 1
09/13/2007 5:41 AM
You know, the first time I calculated it, I looked at the current, and I used square root... then I posted the wrong answer for some reason and I go and insist on the rong idea.
sorry, you're right.
it is the squareroot value
09/13/2007 8:46 AM
NO IT ISN'T YOU MUPPET.
09/13/2007 8:47 AM
Oh..sorry, just saw your retraction...
09/13/2007 4:57 PM
thanks, I know what you meant, you know what I meant. I= √(I²)
09/17/2007 6:51 AM
I must have missed something here but it wouldn't be the first time. If P=I²R with P=0.6W and R=1-ohm, isn't the current 0.77A? One of the posters who gave the table of max current with a 0.6W resistor even had 0.77A limit for a 1-ohm.
Eschew obfuscation.
09/13/2007 7:10 AM
Your resistor for 5A has 24mOhm, that for 10A only 6mOhm for the rated power.
Thats only some cm of wire of a selected material, perhaps wound up to a small coil.
If you need small resistors of these values you should look at some SMD-parts of
ISABELLENHUETTE.DE.
Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
09/13/2007 7:36 AM
He He he I'm going to throw a spanner in the works by asking...
What about 0.25watt zero ohm links then??
I bet they have a maximum current rating???
John.
I was asked once by the buyers at a company what tolerance are the zero ohm links I wanted to use.... LOL
09/13/2007 8:49 AM
Yes but it's probably much more than the pcb track...
Tolerance.. that'd be zero +/- 8000%
Good Answers: 18
09/13/2007 9:35 AM
Actually, fuses are low-value resistors. I know resistors can be fuses from experience.
Good Answers: 54
09/14/2007 10:17 PM
Mathematically yes, they can be be used in 5 to 10 amp circuits if their resistance is between 0.006 and 0.024Ω.
R = W / I2
R = 0.6 / 52 or R = 0.6 / 102
R = 0.024Ω or R = 0.006Ω
Practically, however...no.
It should be obvious, now, that you can't get any commercial resistors of these values from any store. Sure, you can connect resistors in parallel to get these resistances but what circuit would use these values?
Then again, when you deal with such small resistances, other resistances can affect the final value. Things like, a hook up wire, a Printed Circuit Board trace or a solder pad. These also have very small resistances and will add to your "resistors" and affect the circuit.
Reply to Forum Thread 22 comments
Anonymous Poster (7); aurizon (1); bhankiii (2); Bill (2); Electroman (1); Kyoto (1); U V (1); user-deleted-1105 (5); uweka (1); Vulcan (1)
