Previous in Forum: Piezoelectic Transducer Design: I Need Better Crystals   Next in Forum: pipe bender
Mechanical Advantage vs. Efficiency: What's the Difference?
09/14/2007 11:54 AM
Hi friends,
What is the meaning of Mechanical Advantage? What's the difference b/w mechanical advantage and efficiency??? (why we use two different terms)...plez tell me in detail....
Good Answers: 15
Re: Mechanical Advantage vs. Efficiency: What's the Difference?
09/14/2007 1:32 PM
downhill slide to 112 (damn memor.)
09/14/2007 5:35 PM
They are nothing to do with eachother. The mecahanical advantage of say a simple lever would be calculated from the distances between load and fulcrom and effort and fulcrum. The efficience would just depend on how much the lever flexed , how much friction was in the fulcrum, how effectively the load was connected to the lever.
So one is to do with the theoretical advantage * gained by the levers pulleys etc. the other is about the practical physical losses in the system.
* Of course what is gained as 'advantage' in force is counterabalanced by an increase of 'distance moved'.
I'm sure others will add a more rigorous alaysis...and I'm will ing to be shot down on the detail. But this is probably a good start point.
09/15/2007 4:44 AM
Many years ago, when I was at school, the simplest way of finding the efficiency of a mechanical system was taught as:
Efficiency = MA/VR
Where MA is mechanical advantage (load / applied force)
and VR is velocity ratio (distance moved by applied force / distance moved by load)
Madness is all in the mind
09/16/2007 7:07 AM
Del>
Nobody dares to shoot a simple truth-and all the truth -down!
good start point-- You can say THAT again.
09/15/2007 12:05 PM
Mechanical advantage deals with how much force one has to put in to move a given load
MA = load/ Force(used to lift the load)
Efficiency has to do with the ratio of the work done on the load to the energy used up in moving the load
E = work done on load / energy used up to move load (usually expressed as a percentage - 100% or less max E = 100%)
A pulley system or a lever (a long pole -stick pipe) can increase mechanical advantage - that is, you can use it to move something heavier than you can normally lift by your self
MA is usually a number greater than one (1) so a MA of 4 means you only require a quarter of the weight of a load (a bag of potatoes on a pulley) to lift it.
For a lever the efficiency =
E = (weight of load X distance moved)/force that 'you' apply X the distance moved
In an ideal system the energy you put in should be the energy you get back out but this is never possible so that efficiency is never 1 or 100%
hope that helps
09/16/2007 4:16 AM
thanks a lot for all....
Register to Reply 6 comments
Anonymous Poster (2); ddk (1); GM1964 (1); MUKULMAHANT (1); user-deleted-1105 (1)
