I am dealing with an existing wastewater system which has a dispersal field with an infiltrative surface area of 140 square meters. The design flow rate is 27,000 liters a day but only for four days of the year, during a special event. The measured BOD5 and TSS are around 300 and 170 mg/l respectively. Since this is shower water only there is no primary treatment except a filter chamber which removes most of the hair and soap scum, FOGs are minimal.
I am looking for some indication as to how the soils, (primarily fluvial gravels with silty lenses) will respond to this type of flooding, especially in the long term. What benefit would be gained by incorporating aeration into the system to lower the BOD? I assume some type of biomat will develop over time and affect the infiltrative rate but over how much time?
