Previous in Forum: stepper motor problem   Next in Forum: PIC interrupt help
Looking for Electric Motor
09/15/2007 9:37 AM
I have an inquiry from a friend asking for an AC ELECTRIC MOTOR specifically for vertical application. The specification are as follows; explosion proof, 30HP, 460V, 3 phase. Should you require additional information, please post so I can have further inquiry from him.
The installation of the motor is for vertical application. But the installed motor of the plant is for horizontal installation, however it is installed in a vertical position.
Please, post websites that this motor are available.
Re: Looking for Electric Motor
09/15/2007 9:43 AM
What is the manufactur of the electric motor in use?
The name plate with the information on the motor is a good start for your research.
With out this information, everyone is dead in the water.
09/15/2007 11:08 AM
Its quite simple.Motor can be used in Vertical Position by two methods.One is vertical Flange mounting which is not the case as I can Infer.The other is to use a foot mounted motor mounting it vertically with feet mounted on a wall or suitable support with shaft pointing downward or upwards. Normally first is directly coupled and second is used with a belt drive. This motor can be supplied easily .You can send ur enq to me at :nesubra@gmail.com.It will be better if you can send a sketch of mounting and coupling .The belt pull should be towards the base otherwise special construction is to be used.Pl. send the following details if u want a one to one replacement.
Frame Size., Speed in RPM or No of Poles , Voltage , Frequency , Insulation class, Ambient temp for which motor is made, Hazardous area classification whether Zone 1 Or 2A ,Ab as it is a Flame proof motor Particularly if it is 2c Hydrogen then few manufacturers only exist.All above can be taken from the nameplate of the motor.Hope above is useful.
09/16/2007 9:08 AM
Go the easy way on ebay!
09/16/2007 2:20 PM
Results 1 - 10 of about 12,200,000 for Electric Motors. (0.08 seconds)
Good Answers: 18
09/17/2007 8:33 AM
Pump motors made for vertical use have bearings made for axial and radial loads. See if one of those can be adapted.
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
09/21/2007 2:38 AM
Though I am not supplier, I would like you to mention about the motor required is flange mounted, and give the details of hazardous area with the presance of hazardous liquid/gas/vapor etc., to be in atmosphaere at the location of installation.
nascon
Register to Reply 6 comments
Anonymous Poster (1); Bill (1); fliptop427 (1); LordMaximo (1); nascon (1); user-deleted-5 (1)
