Previous in Forum: Water Heater Installation Mini   Next in Forum: Impressive New Night Vision Technology from UCLA
20 comments
Hydropower
06/28/2018 5:18 AM
How much energy,theoretically and realistically, can be produced by 3000 gallons per minute of water,falling from a height of 100 ft,using the current alternator-turbine technology?
Thanks in advance for all feedback on this!
Re: Hydropower
06/28/2018 6:49 AM
This page has a formula to figure it out.
Re: Hydropower
06/29/2018 6:21 AM
Great link! Thanks!
Re: Hydropower
06/28/2018 11:08 AM
3000 gpm x 8 lb/gal x 100 ft = 2,400,000 ft lb/min
2400000 ft lb/min x 1 hp/33000 ft lb /min = 72.73 hp
2400000 ft lb/min x 1 W/44.25 ft lb /min = 54.237 KW
Hydroelectric plants are about 90 percent efficient, so about 49 KW.
http://www.wvic.com/Content/Facts_About_Hydropower.cfm
Good Answers: 137
Re: Hydropower
06/28/2018 1:09 PM
Somewhat optimistic, IMO. 90% efficiency for the alternator would be good going, as would 80% for the turbine, giving close to SolarEagle's 40kW at most. Those efficiencies probably generous for such a small system.
Re: Hydropower
06/29/2018 1:43 PM
Unfortunately, mini-hydro units do not have nearly as much efficiency as the "big boys".
Re: Hydropower
06/28/2018 11:10 AM
Re: Hydropower
06/28/2018 2:21 PM
I see 49 KW, and 40 kW as answers???
I see no kWh.
Is it me, or are we missing something?
Re: Hydropower
06/28/2018 2:40 PM
Around 368,000 kWh annual output ...
Good Answers: 137
Re: Hydropower
06/28/2018 2:51 PM
OK, OP did say energy, not power, but as he didn't say over what time period, power seems more useful. I'm sure he can take it from there!
Re: Hydropower
06/28/2018 4:21 PM
He should have asked for power, not energy, having given gallons per minute...
Re: Hydropower
06/28/2018 4:54 PM
After all, he is a Hi Tek Red Nek.
He only looks like Nikola Tesla.
Re: Hydropower
06/29/2018 6:31 AM
I actually wanted energy and power,hence the mixing of terms,but I should have been more explicit considering the highly esteemed and educated populace of this blog.
I will try to clarify in the future.
As for being a RedNek,yes, I am,and proud of it.
We even passed a law recently declaring that if you and your wife get a divorce,she can still be your cousin.
This country owes a lot to rednecks,for instance:
The toothbrush was invented in Arkansas.
Anywhere else,it would have been called a teethbrush.
Thanks for the valuable feedback and compliments from everyone.
Re: Hydropower
06/29/2018 11:42 AM
And the Arkansas toothpick.
Re: Hydropower
06/29/2018 1:36 PM
No need for a toothpick when you only have 1 tooth.
Dat iz a grizzly bar rib rench.
Donchoo no nuttin boy?
I got mi fist one when I wuz 3.
Re: Hydropower
06/29/2018 1:47 PM
As there is a rate in the input data, and not a quantity, the output is the rate of doing work, i.e. the power, and not the quantity of work available, i.e. the energy.
Re: Hydropower
06/29/2018 2:57 AM
<...missing something?...> No, because the original poster does not state the quantity of water available, so all that can be known is the rate: <... no kWh...> is understandable.
Re: Hydropower
06/29/2018 6:33 AM
Simply multiply by the number of hours operated.
Re: Hydropower
06/28/2018 6:56 PM
What good is power if it does no work?
That's enough power to run 4,000 sewing machines continuously.
Good Answers: 137
Re: Hydropower
06/29/2018 5:53 AM
Lyn, I think you're trying to wind us up!
Power for any length of time (> 0) does work.
Re: Hydropower
06/29/2018 6:04 AM
<...wind...up...> Stitch, more like.
Register to Reply 20 comments
Codemaster (3); Doorman (1); Dr. Harry (1); HiTekRedNek (4); JPool (1); lyn (3); PWSlack (3); Rixter (2); SolarEagle (2)
