Previous in Forum: Effect of Rotor on Stator Winding Inductance in an Offline Generator   Next in Forum: 3VA PT/VT Measurement and Safety/Accuracy
Substation Grounding System
06/30/2018 1:28 AM
Dear Sirs,
Determination of soil resistivity is important for designing substation grounding systems.
For example: if a substation under consideration reads 270 ohms meter to 4.5 kilo-ohms of resistivity when the soil resistivity was measured - what value of resistivity should be considered for designing substation grounding systems?
I understand that - we are only measuring apparent value of soil resistivity and this is used to find the reduction factor for derating the nominal value of surface layer resistivity.
The best (lowest) value obtained (for 1 metre electrode spacing using wenner method) is 270 ohm metres. Can this value be considered for substation grounding system design?
Regards,
Re: Substation Grounding System
06/30/2018 10:30 AM
Good Answers: 444
06/30/2018 9:57 PM
...and after you have the facts, get the standards that are applicable to the installation and its locale, then have your design approved by an electrical engineer who has experience dealing with the AHJ.
Good Answers: 117
06/30/2018 11:59 PM
Here try this... and next time do your own research!
LINK
07/01/2018 10:00 PM
The resistance value you measure may well be accurate on the day you measured it. But the resistance value limit is whatever the standard the substation grounding is to be built to says it needs to be, and if you cannot achieve it with the existing soil resistivity then you dig earth pits and use additives and extra earth rods and otherwise lower the resistivity of the site until you can achieve it.
This needs to be included in the design and costs when building the substation.
07/02/2018 8:48 AM
...and soil resistivity varies with a number of factors, not least of which is the amount of moisture in the soil. Among the techniques for reducing it is the pouring of a tanker-load of seawater into the soil immediately where it is to be measured, though this may have unwanted impact on the vegetation in the area. If none is available, bovine urine would seem to make a reasonable substitute.
In the limit, the soil resistivity has to be low enough to operate any applicable circuit protective device in the event of a fault, and equipment needs to be selected accordingly. There are national standards for such things, which one would be well advised to follow.
brich (1); jack of all trades (1); lyn (1); PWSlack (1); RAMConsult (1)
