Previous in Forum: Protection   Next in Forum: VT Protection
10 comments
ACS 850: What is A.154 or A.70
07/04/2018 9:37 AM
ACS 850 follower drive has parameter 21.01 = A.154. I am unable to understand what is this if anyone can help??
Re: ACS 850 ...what is A.154 or A.70
07/04/2018 10:19 AM
I'm sure someone at ABB can help. I suggest you e-mail them, or telephone if it's urgent.
07/04/2018 10:32 AM
Local vendors have no answer.....they forwarded to higher levels ...let's see when I get result
07/05/2018 3:13 AM
If <...get result...> is what is truly wanted, then pick up the , because that is what it is for. "Time is money." - Anonymous Poster #0
07/04/2018 10:39 AM
You definitely need somebody from ABB to assist you with setup on these controls...
https://library.e.abb.com/public/cc976018da34d40dc1257c7600303aa3/EN_ACS850_FW_%20I_A5.pdf
07/04/2018 10:53 AM
You're right there. The section on parameters in ABB doc 3AUA0000045497 (Firmware Manual, ACS850 Standard Control Program) has nothing remotely like A.154 in the entries listed for parameter 21.01
07/04/2018 11:07 AM
It might mean that the control engages start automatically when the residual magnetic hysteresis reaches a certain percentage ....but I'm just guessing....
07/04/2018 1:17 PM
Never seen anything like this in ABB drive.
Hope someone have encountered this problem and have some clue for this
07/05/2018 3:51 AM
<...Hope...> is not a strategy. This places other people, with no incentive to help, in control of the outcome.
is the tool that will yield results, and all that is missing is the skill and willingness to use it. "Time is money." - Anonymous Poster #0
Good Answers: 19
Re: ACS 850: What is A.154 or A.70
07/06/2018 3:48 PM
They are fault codes.
Good Answers: 804
07/09/2018 8:48 PM
21.01 is where you specify the Speed Reference signal to come from. I suspect that you are reading it when the drive is running, so you are seeing a code of some sort, relating to the "D2D" (Drive to Drive) reference "pointer" that is taking the speed command FROM some register in the other drive.
They aren't fault codes though, ABB uses 4 digit numerical codes for faults.
Register to Reply 10 comments
abhisinghin (2); JohnDG (2); JRaef (1); PWSlack (2); SolarEagle (2); Stedou73ish (1)
