Previous in Forum: Connecting A Buzzer To My Infrared Proximity Detector?   Next in Forum: Cable Jointing
Overvoltage
09/18/2007 3:45 AM
What is overvoltage and how can it be solved in a distribution system?
Re: overvoltage
09/18/2007 4:59 AM
Good Answers: 804
Re: Overvoltage
09/18/2007 4:30 PM
LOL,
I can't believe there is a Wiki entry for something so simplistic, but then again, the question came up didn't it?
Over = above, in excess, more than enough, etc. etc.
Voltage = .... well, voltage.
Overvoltage then = too much voltage.
Follow that?
Good Answers: 804
Re: Overvoltage
09/18/2007 4:34 PM
Ok, I was being cruel, sorry.
What I meant by that was, maybe rather than ask something so vague as to be ridiculous, you should define your issue a bit more. For instance, "What percentage of nominal voltage is typically considered to be "overvoltage" on a 480V system feeding an AC motor?" Or perhaps "How much over my 12.47kV distribution voltage is going to be dangerous to my transmission systems?" Or even, "I have a TTL logic level system receiving 5.32VDC instead of 5VDC. Is that considered "overvoltage"?"
You see over and voltage can be different things to different people. So of those way would more reasonable for stating your problem.
Re: Overvoltage
09/19/2007 6:00 AM
none can answer this question.
bexaue 1V can be overtage, 10V can be, 1000vcan be as well.
we can also say 10kv is undervoltage, so what is reference?
distribution system has various power supply.
Re: Overvoltage
09/20/2007 1:49 AM
Overvoltage in any type of distribution systems is the highest or threshold limit of voltage capabilities of connected loads. You can also say the safe limit of connected loads.
If you have 380/400/440 or 11kv..... system, then there are many programmable overvoltage controllers available in the market even if you want to make your system more sophisticated, you can adopt protection relays that can controls over/under voltage, current,frequency etc.
Good Answers: 61
Re: Overvoltage
09/20/2007 9:35 AM
This sounds suspiciously like a homework question.
Register to Reply 6 comments
Anonymous Poster (1); cnpower (1); JRaef (2); pwr2thepeople (1); Syed Ziauddin (1)
