Previous in Forum: Re: Heaters for Pressure Vessel   Next in Forum: How Can I Convert XYZ to LRA?
Rework of Hardness for FG 260 Material During Stress Relieving
07/15/2018 11:16 AM
We have stress relieved FG260 crankcase of wall thickness 22 mm at 720 degrees centigrade for 1 hours 30 minutes, due to which the BHN hardness value has reduced from 210 to 150 BHN. Electric furnace is used for Stress relieving .
We want to rework the same to get a minimum BHN of 200. Please suggest the rework procedure / process
Thanks in advance,
Ravi Bagewadi
Re: Rework of hardness for FG 260 material during stress relieving
07/15/2018 12:06 PM
Your aging temp seems high.....recommended 520 to 580C...and your time seems too short, recommended @ 4-6 hrs....
https://www.castingquality.com/wp-content/uploads/2010/07/grey-cast-iron-composition.pdf
07/15/2018 12:31 PM
Location: crankshaft producing hub in belgaum,karnataka,india
07/15/2018 12:40 PM
thank you Sir,
07/15/2018 12:12 PM
07/15/2018 10:24 PM
Thank you very much .
I will try to reduce temp to 580 Deg, and adopt soaking time of 2.5 - 3 hrs for 22 mm wall thickness.
And for rework use 850 Deg. 1 HR soaking and forcibly cool with fan
07/16/2018 3:03 AM
Once it is done and proven to work, write it up as a production standard for others to follow.
lyn (1); PWSlack (1); ravi bagewadi (2); SolarEagle (2)
