Previous in Forum: Rework of Hardness for FG 260 Material During Stress Relieving   Next in Forum: Best Way to Remove Copper Enamel Coating from Magnet Wire
How Can I Convert XYZ to LRA?
08/11/2018 1:15 PM
Hi All,
I would like to convert XYZ data from drawing to LRA and implement it into my software (C# language). I have read and following research "B-CODE GENERATION FOR A CNC DENTISTRY WIRE BENDING MECHANISM" as in paper doesn't have CLR , Outer diameter, Wall Thickness of tube, so the result not correct for me.
anyone can tell me about formula convert XYZ to LRA? Thanks.
Re: How can I convert XYZ TO LRA
08/11/2018 2:17 PM
08/11/2018 2:30 PM
Hi SolarEagle,
Thank you for this link, I visited this site but I not see formula that him calculate in his application. I would like to know ,How does he convert XYZ to LRA ?
08/11/2018 3:44 PM
Using mathematics...
https://www.freemathhelp.com/forum/threads/111090-Converting-XYZ-Coordinates-to-LRA-(Length-Rotation-Angle)-Values
%XYZ2YBC convert form XYZ coordinate to YBC format (LRA)
% XYZ2YBC(X,Y,Z) convert the X,Y,Z values to Y,B,C values. assuming the bend
% radius is zero. the size of X,Y and Z must be the same.
% XYZ2YBC(X,Y,Z,R) where R is the bend radius. convert the X,Y,Z values to
% Y,B,C values, taking in to account the bend radius R.
% XYZ2YBC(X,Y,Z,R) where R is the bend radius matrix for each bend. convert
% the X,Y,Z values to Y,B,C values, taking in to account the bend radius R
% for each bend. size of R must be less than the number of XYZ points by 2.
% returns Y length between bends, B rotation between bends in radius,+ for
% clockwise and - for anticlockwise, C angle of bend in radius.
% File: xyz2ybc
% Author: Ammar Mousali
% Date: 29/04/2004
% Griffith University
% V1.1
% changes from V1.0
% changed the output from degrees to radius.
function [Y,B,C] = xyz2ybc(Xc,Yc,Zc,R)
if( (length(Xc) ~= length(Yc)) | (length(Xc) ~= length(Zc)) )
error('X,Y,Z are not the same size');
end
if(nargin == 3)
% set the bend radius to zero for all bends.
R = zeros(1,length(Xc)-2);
elseif(length(R) == 1)
% set the bend radius to R for all bends.
R = ones(1,length(Xc)-2).*R;
elseif(length(R) ~= length(Xc)-2)
error('R size doesnt match the number of bends');
end
% number of bends is less than the number of XYZ points by 2.
for i = 1:length(Xc)-2
% calculate the 2 vectors BA and BC, representing an angle ABC.
V1 = [Xc(i)-Xc(i+1) ; Yc(i)-Yc(i+1) ; Zc(i)-Zc(i+1)];
V2 = [Xc(i+2)-Xc(i+1) ; Yc(i+2)-Yc(i+1) ; Zc(i+2)-Zc(i+1)];
% calculate the length of vectors BA and BC.
V1l = Vlength(V1);
V2l = Vlength(V2);
% calculate the angle between the 2 vectors BA and BC.
C(i) = pi - acos(dot(V1,V2) / (V1l*V2l));
% calculate the vector perpendicular to the plan ABC.
planeV(i,:) = cross(V1,V2)';
if(i>1)
% calculate the length of the straight by subtracting the tangent of
% the bend angle.
Y(i) = Y(i) - R(i)*tan(C(i)/2);
Y(i+1) = V2l - R(i)*tan(C(i)/2);
% calculate the length of vectors perpendicular to the plan ABC and
% the plan of the bend before it.
PV1l = Vlength(planeV(i-1,:));
PV2l = Vlength(planeV(i,:));
% calculate the rotation direction. negative if counter clockwise.
s=sign(V1 .* cross(planeV(i-1,:),planeV(i,:))');
% calculate the rotation angle and multiply by the rotation direction.
B(i) = acos(dot(planeV(i-1,:),planeV(i,:))/(PV1l*PV2l))*s(1);
else
% the bend angle.
Y(i) = V1l - R(i)*tan(C(i)/2);
% rotation of the first bend is always zero.
B(i) = 0;
end
end
% calculate the length of a 3D vector.
function l=Vlength(V)
  1. l = sqrt(V(1)^2 + V(2)^2 + V(3)^2);
https://www.mathworks.com/matlabcentral/fileexchange/6100-convert-form-xyz-coordinate-to-ybc-format-lra
08/12/2018 10:11 AM
Hi SolarEagle,
To day I install matlab and test function xyz2ybc , It work for me.
Thank you so much.
08/12/2018 12:58 PM
It's a miracle!
Re: How Can I Convert XYZ to LRA?
08/13/2018 11:47 AM
I have last question, How can I calculate "NET Length in LRA" ? see images.
08/13/2018 1:17 PM
Transfer your image to Solidworks or Sketchup and use a ruler....
Register to Reply 7 comments
