Previous in Forum: CD Nozzle And The Adiabatic Process   Next in Forum: Precision cutting blades for Silicon
12 comments
Looking for cheap domestic flow meter
09/21/2007 10:26 AM
I'm looking for a cheap flow meter, for 1/2" domestic installation to measure volume of water used.
I am guessing that it will be either paddle wheel or pelton wheel with hall effect output if that is the most cost effective method.
Requirements:
  • Must be small and needs basic display of flow volume up to 999 litres.
  • Display can be digital or analogue
  • If poss, a reset (to zero) button.
  • Flow rate will be no more than 20 litre/min but more like 10.
  • Accuracy not important (not worse than +/- 10% though)
Does anyone know if such a thing exists?
Pathfinder Tags: flow meter water measure
United States - Member - NY Engineering Fields - Aerospace Engineering - RPI Class of '05 Engineering Fields - Energy Engineering - Steam Turbine Aero Design Engineer
Re: Looking for cheap domestic flow meter
09/21/2007 10:41 AM
Paddlewheel flow meters are typically inexpensive. These are the results from a quick search using some of the specs you mentioned. If you're only looking for 1 - try your local hardware store.
09/21/2007 10:55 AM
I've done this search too but these are way over-engineered for what I need. I'm in the market for thousands but have to be basic - no stainless, no fancy bearings...
PVC is good!
09/22/2007 4:42 AM
How about 'Rotameter'?
If rotameter is ok, I can suggest as how to construct a simple rotameter without tapper tube...
09/22/2007 11:51 AM
If you want n000,your best,cheapest,most reliable will be to get same in 3parts:
  1. Multivane flowthrough fan with SS WIRE shaft going out through Teflon/Nylon seal/bush. Low pressure--PVC/metal Flow- through chamber. No /tiny leak.
  2. Shaft end pasted with mirror to create 1 bit pulse for counting. LED+ optopulse detector in a dark hood.
  3. Detector to scaler+readout=standard IC's.
I can supply 1+2 in 2 months of developmental trials.
MM
09/21/2007 11:00 PM
Ace hardware or whatever your local hardware store is...
Good Answers: 120
09/21/2007 11:14 PM
Per Ardua Ad Astra
09/22/2007 12:34 AM
Try your local city water works...they remove and discard what you are looking for to ensure our house meters are reasonably accurate.
Good Answers: 50
09/22/2007 6:07 AM
Do a search on eBay. I found some really good ones there for cheap.
09/23/2007 8:38 AM
Thanks all for your help.
The GPI 01 series (Nylon) is close to what I'm after but only comes in 1 inch. Does anyone know of a 1/2" variant?
Any manufacturer/country acceptable.
09/23/2007 8:28 PM
Just go with a reducer bushing on each end. A 1" to 1/2" reducer,...
09/24/2007 2:33 AM
Check out Ista
They are specialised in this range of equipment, and when I asked the price for the meters with the m-Bus module it was not so expensive (€ 70,-)
09/24/2007 5:21 AM
Register to Reply 12 comments
Anonymous Poster (3); aurizon (1); Gwen.Stouthuysen (1); MUKULMAHANT (1); PWSlack (1); smiggins (2); t-rex (1); vermin (1); yesyen (1)
You might be interested in: Gas Flow Meters, Flow Meters, Air Velocity Flow Sensors
