Previous in Forum: Design Report   Next in Forum: Screw Part Number Equivalent
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
Bearing cooling water
09/21/2007 12:09 PM
Request for advice,on what is meant by 'Bearing cooling water system' & What is the preferred system of cooling bearings?
nvmani
Re: Bearing cooling water
09/21/2007 11:01 PM
more information on application please.
Popular Science - Weaponology - Chronic intel collector
09/22/2007 1:41 AM
I think what you want to know is what water-cooled bearings are? should find usage where large quntities of water is available easily and cheap well here is how the concept of Water-cooled bearings work Cooling and lubrication arrangement for water cooled bearings having self contained lubrication systems
AFAIK bearings are also cooled by means of lubricating oil. If the temp that the bearing is expected to reach is not to exceed 100 degees C, then no special provision is to be made for cooling the bearing. But if it exceeds that temperature, then it is expected to use lubricating oil Along with providing lubricating effect to the bearing, the lubricant will also carry away the heat generated by frictional losses, thus mantaining the temperature of the bearing within acceptable limits :)
Get busy living.... Or get busy dying - The Shawshank Redemption
09/22/2007 2:02 AM
The primary coolant is still lubricating oil. But in order to ensure that the coolant temperature does not exceed its oxidation temperature, provision is made to transfer the heat to water surrounding it (through an interface surface)
09/22/2007 3:13 AM
Thank you for the clarification. The concept is well understood.
nvmani
09/23/2007 3:34 AM
Coming back to the same topic:
When lubricating oil temperature exceeds its oxidation temperature i.e.100 degree centigrade,heat is transferred to water. It is possible that water gets converted to steam at this temperature. Please advise whether such situation can arise?
nvmani
09/23/2007 12:28 PM
well if the heat transfered to the water by the lubricating oil raises the temperature of water to 100 C, then, assuming normal atmospheric pressure, it will get converted into steam. This steam will then have to be delt with, by condensing it.
But, the important point here is that the lubricating oil is preserved for further use. It is a lot easier/economcal to replace the water than to replace the lubricant. Regards :)
Register to Reply 6 comments
Anonymous Poster (1); nvmani (2); slugger (3)
