Previous in Forum: Schematic for a lube oil skid   Next in Forum: Gas turbine fuel options
Crank shaft design
09/22/2007 9:18 PM
Hello Friends,
I want to design crankshaft for horizontal triplex plunger pump of capacity 200 gallons/min, operating pressure 4000 psi, what design methodology should i adopt.
Regards
Ahmad Bilal
Re: Crank shaft design
09/22/2007 9:45 PM
You are building a 4000 psi triplex pump from scratch? Uh you do know there are companies that make these?
I don't mean to be rude, but if you are asking this question here, you have no business trying to design such a part, and if you carry on it very likely will get someone hurt or killed.
09/24/2007 3:57 AM
Please go and look at the following web site and see if the need is so strong that you might remove your genes from the world pool!
http://darwinawards.com/
If not, go and buy from professionals.....
Remember that 4000PSI is a deadly amount of air pressure, that can be likened to several sticks of dynamite at very close quarters.....
11/02/2007 11:46 AM
OPI, National Oilwell-Varco and others make these all day long and you can buy them off the shelf. Are you looking to rip off their design and make a clone of it?
Register to Reply 4 comments
Andy Germany (1); Anonymous Poster (1); Steve S. (2)
