Previous in Forum: Crank shaft design   Next in Forum: RFG Compressor in Power plant
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
Gas turbine fuel options
09/23/2007 9:09 AM
Gas turbine uses fuels like naphtha,Diesel,natural gas,kerosene,combination of diesel and fuel gas etc. What is the fuel originally intended as per design of Gas turbine? For example,for GE frame 3 and 5 machines?
Request help from CR4 friends.
nvmani
Re: Gas turbine fuel options
09/23/2007 10:17 AM
Natural Gas.
09/23/2007 10:22 AM
The frame 3 and 5 we intended as mechanical drives (compressor drives) and since natural gas compressors are probaly the most common, it's natural fuel is natural gas.
Popular Science - Weaponology - Chronic intel collector
09/23/2007 3:12 PM
General Electric Frame 3&5 Gas Turbine were both designed to use Natural Gas as fuel
Get busy living.... Or get busy dying - The Shawshank Redemption
09/24/2007 6:00 AM
In our plant,combination of Refinery fuel gas(90%)and HSD (10%) is used as GT fuel. Natural gas is ideal,but if there is no availability of Natural gas,what is the next best fuel option? Is naphtha fuel is more efficient,more economical,than fuel gas(90%) and HSD (10%) combination? Please advise,with more details if known.
nvmani
09/24/2007 8:46 AM
I'd hazard a guess that your best line of enquiry would commence with the manufacturers, aren't they able to help? I'd have thought they could provide settings/modifications that would cover most fuels that you could contemplate using.
Wish I was here more often.
09/24/2007 8:56 AM
Many older Frame 3 & 5 in the power generation industry use diesel. Some are dual fuel, diesel or natural gas. Most new GE Frame turbines are natural gas.
Register to Reply 6 comments
Anonymous Poster (1); nova85 (1); nvmani (1); slugger (1); Steve S. (1); Wrenched (1)
