Previous in Forum: Legal Punishment of Law by Acquiring Service and Operational Manuals and Diagrams   Next in Forum: Next Time Your Car Dies Should You Just Put it in the Garage?
8 comments
Container Wind Load: Part 2
08/12/2018 3:05 PM
Hi All, After receiving the adaptive map from a previous post , my efforts to find a local engineer to run calculations on the wind speed tip over point of a conex shipping container have not worked . Can anyone help with this. Info ,40ft hi cube 8ft wide x 9.5 tall x 40ft long. — — 20ft standard. 8ft wide. 8.5 tall 20ft long. Specs below. Would like calculations for empty weight,— -2000lbs— -and 4000lbs weight load, on floor , and for increased stability by nesting side by side. Containers are placed on flat prairie ground . previously we had these at 9000ft rocky mountain location with winds 120–130 mph. Never had any issues. Thank You http://containersolutions.net/specifications/ http://adaptivemap.ma.psu.edu/websites/friction/slipping_vs_tipping/slippingvstipping.html
Re: Container wind load :part 2
08/12/2018 3:28 PM
F = A x P x Cd
F = Force
A = Area
P = Wind Pressure
Cd = Coefficient of Drag (for a flat surface such as a container it would be 0.6)
...as you increase altitude you decrease air density, so 120 mph wind at sea level does not equal 120 mph wind at 9000 ft altitude in force....
10' shipping containerSteel
20' shipping containerAluminiumSteel
40' shipping containerAluminiumSteel
40' high cube containerAluminiumSteel
45' shipping containerAluminiumSteel
110 mph
120 mph
130 mph
140 mph
150 mph
https://containerauction.com/read-news/shipping-container-wind-rating-and-load-capacity
https://sciencing.com/calculate-wind-load-large-flat-surface-12079539.html
08/12/2018 4:06 PM
Specs
Typical ISO (International Standards Organization) shipping containers are manufactured with identical size specification in terms of exterior height, exterior width, and exterior length. The standardization of containers and the adoption of the ISO specification is to insure that all equipment handlers, chassis, rail cars, and slot spaces on vessels will accommodate ALL containers. This makes our job much easier, because we can confidently give you exact exterior specifications. Interior specifications can be slightly different, less then 1″ variation. These ISO containers are now available in all major metropolitan areas throughout the nation. Shipping containers as storage units have changed the storage industry, most people prefer the convenience of mobile storage vs. standard mini storage. Container Solutions has formed a network of small businesses that are familiar with your needs. This guide is designed to help you become informed about container uses, common questions and problems.
Typical Dimensions
ExteriorInteriorDoor Opening
LengthWidthHeightLengthWidthHeightWidthHeight
10′ Standard Dry Container10′8′8’6″9’3″7’8″7′ 9 7/8″7’8″7’5″
20′ Standard Dry Container20′8′8’6″19’3″7’8″7′ 9 7/8″7’8″7’5″
40′ Standard Dry Container40′8′8’6″39′ 5″7’8″7′ 9 7/8″7’8″7’5″
40′ High Cube Dry Container40′8′9’6″39′ 5″7’8″8′ 10″7’8″8′ 5 1/2″
45′ High Cube Dry Container45′8′9’6″44′ 5″7’8″8′ 10″7’8″8′ 5 1/2″
20′ Refrigerated Container19′ 10.5″8′8’6″17′ 11″7’6″7’6″*7”5″7’3″
40′ Refrigerated Container40′8′8’6″37′ 11″7’6″7’6″*7”6″7’6″
40′ High Cube Refrigerated Container40′8′9’6″37′ 11″7’6″8’4″*7”6″8’4″
Typical Weights / Capacity
Cubic CapacityTare WeightMax GrossMax Payload
20′ Standard Dry Container1,165 cu. ft.5,05067,20062,150
40′ Standard Dry Container2,350 cu. ft.8,00067,20059,200
40′ High Cube Dry Container2694 cu. ft.8,77567,20058,425
45′ High Cube Dry Container3043 cu. ft.9,81072,80062,990
20′ Refrigerated Container1,010 cu. ft. (967)**6,50352,80046,407
40′ Refrigerated Container2,051 cu. ft. (1959)**9,70067,20057,450
40′ High Cube Refrigerated2,380 cu. ft. (2,289)**9,59070,55060,960
08/12/2018 4:09 PM
Solar Eagle, Would your chart/ info refer to structural failure or tipping over?
08/12/2018 5:06 PM
I think that's the approximate sliding or tipping force....
Q- I read that an ISBU Home is Hurricane proof. Is that true?
A- Yes, ISBU Homes, either single units or multiple units connected, can withstand 100 MPH winds on a foundation, or 175 MPH winds when easily anchored with pylons. ...extremely solid in Tornadoes or Hurricanes. This has been proven time after time in many ‘real life’ situations."...
http://www.isbu-association.org/faq.htm
http://www.isbu-association.org/all-about-shipping-containers.htm
https://containerauction.com/read-news/shipping-container-parts-and-assembly
https://containerauction.com/read-news/storage-container-foundation-ideas
08/12/2018 5:28 PM
Re: Container Wind Load: Part 2
08/14/2018 8:38 AM
Is this the first time the forum has needed to consider the flight-worthiness of ISO shipping containers?
08/14/2018 11:15 AM
If you are thinking about using this for tornado protection then look at this.
This may also be why engineers are hesitant to give you a wind speed tipping point analysis.
08/14/2018 12:38 PM
Register to Reply 8 comments
Jazzman (2); PWSlack (1); redfred (1); SolarEagle (4)
