What is the difference in shape between an arch brick and a rotary kiln block? Also, what are the types, sizes and composition of brick used in the kiln?
#1: shaped to form an Arch-cylindrical or round. Arch roof is basically self supporting. All arches are in compression.Typical cylindrical is glass tank roof.And Round is the roof of ARC furnace.
#2 : Brick Id/Od/sides are to form Kiln working ID and Kiln-shell ID.
Composition is a variable. Depends on gasses in the kiln whether or not theres any material in actual contact with it, how its heated, and to what temperature. Also you could consider a moldable or castable refractory. Mixes and pours like concrete.Pryor Giggey Co.
The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair...Douglas Adams
