Previous in Forum: A Short Video on 'What Does a Hydraulic Engineer Do?'   Next in Forum: Good House Building
19 comments
Speed
10/14/2018 7:27 PM
Sailing down wide mountain river at 7pm. River speed 5 mph . How fast is the boat going.
Re: Speed
10/14/2018 8:07 PM
Insufficient information.
Re: Speed
10/14/2018 8:35 PM
With or without any wind? By 7 p.m., wind should have died down already.
Re: Speed
10/14/2018 9:36 PM
No prevailing wind.
Re: Speed
10/14/2018 8:38 PM
6 mph backwards due to a strong opposing wind on the sails.
I had to make a few assumptions like location, boat configuration and when this river excursion occurred.
Re: Speed
10/14/2018 9:30 PM
The boat is not moving, they've come to a low bridge that doesn't open past 6pm , and must anchor for the night....
Re: Speed
10/14/2018 10:13 PM
Get a fancy watch.
Re: Speed
10/14/2018 10:49 PM
If you're sailing down a river riding a 5 mph current, you must be under power to maintain steerage, so we will assume you are under power and not just drifting....the maximum speed is usually determined to be 1.34 times the square root of the waterline length, so for example if your waterline length is 25' then it would be 5 times 1.34 = 6.7 knots or 7.71 mph, this then added to the 5 mph current speed would be 12.71 mph as a maximum...
Re: Speed
10/15/2018 12:09 AM
...or 2.71 mph upstream.
Re: Speed
10/15/2018 12:25 AM
Would a 10 mph katabatic wind fill the sail ? It's going 5 mph faster than the river. Would it matter if was just a raft. A bigger raft goes faster than a smaller one?
Re: Speed
10/15/2018 1:11 AM
For maximum efficiency a sailboard is the way to go....
Re: Speed
10/15/2018 2:25 AM
A few posts ago, your presumption was no prevailing wind.
Re: Speed
10/15/2018 11:47 AM
A katabatic drain (wind) is cold air high in the mountains sinking quickly down river (in this case) in the evenings. All day heated air rising, after sunset cold air sinking . Thus the question about down river sailing, with no prevailing "wind".
Re: Speed
10/15/2018 3:16 AM
May one assume that the relativistic effects can be ignored?
Re: Speed
10/15/2018 12:02 PM
No, here is a possible answer ...10 mph down river drain, river flowing at 5 mph.
Re: Speed
10/15/2018 3:45 AM
<...at 7pm...>
Why is the time of day of any relevance, please?
Re: Speed
10/15/2018 11:58 AM
Katabatic wind (downward) ,evenings, anabatic (upward) .wind up until sunset
Re: Speed
10/15/2018 8:05 PM
in the mountains, Analytic wind (upward warm air movement) all day, then at sunset, all that air cools and flows quickly downward katabatic wind. It is basically a temperature differential which drives the climate of the world. If there was no differential, there would be no wind. Cold pushes hot.
Re: Speed
10/15/2018 9:13 AM
Who cares? Just enjoy the view, and sip a fine scotch. You're obviously not in a hurry.
Re: Speed
10/15/2018 8:55 PM
Enjoying a down river cruise with my fishing rod, a beer, at 6 mph. Going with the flow.
Register to Reply 19 comments
70AARCuda (1); Gavilan (1); jack of all trades (1); JE in Chicago (1); munch (7); PWSlack (2); SolarEagle (3); Tornado (3)
