Previous in Forum: Who Cares? Real or Fake?   Next in Forum: Point of Use Water Heater (Under the Sink Heater)
12 comments
Location: DUBAI, UAE. 25° 11' 58.2504'' N & 55° 16' 38.6292'' E with 1191 m (3907 ft) elevation.
Suitable Replacement for Ultrasonic Plastic Welding
11/01/2018 3:15 AM
Products that I am trying to weld are HDPE and LDPE plastic with approximately 125 degree centigrade melting point. Space available for welding is very restricted because I have a bag and a cap and there is no way to access inside the bag to apply pressure from inside and outside. We used ultrasonic welding machine but because the alignment between the bag and cap has little change for each bag there are some bags that are not quite fit together and weld break under pressure. So I searched for a suitable replacement to ultrasonic. Now I think I need a procedure with cost efficiency and without so much tolerance to worker’s low accuracy.
This picture is ultimately what I’m trying to achieve but I have no idea how.
One option is laser welding, which is very clean and fast but it is expensive and again prone to misalignment. Another option is heat and which is, I think, my option. But I have no idea how to do heat welding this clean and without so much waste of material.
Any suggestions?
Re: Suitable Replacement for Ultrasonic Plastic Welding
11/01/2018 10:07 AM
I would break this up into 2 operations....I would cut the plastic into 2 pieces, weld the bag to the one piece and then the plastic part 1 to plastic part 2....this strategy would allow access...The hard plastic would have to be split strategically to allow this to work...
Good Answers: 53
11/01/2018 11:00 AM
Instead of weld, I would make a thread on green PC. And tightened the LDPE transparent bag with an external threaded ring on green part.
11/01/2018 11:04 AM
Have you looked at bag sealing technology?
Maybe speak directly to some about your problem.
PAC MACHINERY
1 (234) 222-1000
Good Answers: 153
11/02/2018 5:49 AM
Is it possible to make the rim on the cap tapered so that tolerances in the bag could be compensated by pushing the bag further onto the rim? Then your existing welding procedure would produce reliable results.
Good Answers: 141
11/02/2018 9:37 PM
Forget a hot wire - it cuts through the bag before any welding occurs
You could make a set up that works.
Make a lint of thin stainless steel - as you can recover from a windscreen wiper base. You can heat this up with a low voltage transformer and a voltage regulator.
For packing machine heaters a flexible - self sticking Teflon tape is available.
The principle is that you need to heat BOTH plastics, without melting the bag prematurely - here is the Teflon coming into play- part of the lint needs to be isolated so
that your bag withstands the heat and pressure.
The lint has to be strapped around the ring and bag with some pressure (a mini vise grip with isolated tips can do this
Another way can be hot glue
Plenty of room here
11/03/2018 6:54 AM
Exactly like a plastic packing machine! But I guess for that I need some space and pressure from both sides. This is not available here with my product.
11/03/2018 6:50 AM
Make two parts and thread are not viable solutions. They may be able to do what I need at the moment but price difference is much higher! I need a price efficient technique.
Also put even much more material on another is not necessary, because I have at least one product on my hand and attached it for you that achieve a good weld with at most 5 mm of material on another.
As for what @dvmdsc and @lyn said, I guess that is possible to use a technic like all other bag sealing machines. But still it is not as simple as put two parts together and apply pressure. And what is hot glue? Can anyone give me some idea about where to get it and how to use it to get results?
11/03/2018 2:17 PM
"Hot glue" Hot - melt adhesive - Wikipedia
Is a viable option and very inexpensive. But SLOW! And somewhat messy.
A cheap gun and glue sticks can be bought for $10-15.00 USD. Give it a try, but be prepared to be disappointed.
Good Answers: 141
11/03/2018 7:30 PM
My suggestion:
For a few parts - hot glue
For a small series - make a simple set up with a lint - get a stander to hold the ring in place for reproduction
For bigger series - automate and work with a 2 pieces (halves) heated press
If these proposals looks difficult - get help
good luck
Plenty of room here
11/04/2018 1:12 AM
thanks everybody for your suggestions.
11/20/2018 1:13 PM
Sorry to reply so late, but no one mentioned RF, or dielectric welding. Could be worth a look.
11/21/2018 12:26 AM
thank you. the problem is precision not that i cant weld with ultrasonic, but a little displacement in every one of bags and caps can cause a lot of waste in production line.
i need something that is not that much susceptible to poor accuracy of hand placement of bags and caps!
Register to Reply 12 comments
dvmdsc (2); jhhassociates (1); JRiversW (1); lyn (2); maverick.mk6 (4); rakesh_semwal (1); SolarEagle (1)
