Previous in Forum: 4- 20 mA Transmitter Signal Greater Than 20 mA   Next in Forum: A Problem Related to WinCC
Fluke 435 II Power Quality Analyzer
11/07/2018 11:00 AM
Good day
Could any one tell for how long (maximum time) FLUKE 435 with 8GB SD card can record data before downloading.
Re: Fluke 435 II Power Quality Analyzer
11/07/2018 12:07 PM
I suspect this all depends on how one configures the instrument to capture data. Configuring it to capture a brief time interval (30 sec?) of "good" power quality once but then the same time interval before and after a preset anomaly trigger level will allow this to be monitoring until its batteries die.
11/07/2018 12:13 PM
What redfred said. Sample rate must be considered, size of data file, etc, etc.
Too many vairables to say.
Get a 32 GB sd card.
11/07/2018 1:18 PM
Depends on several things. Are you planning on capturing wave events/transients that exceed certain limits? Those capture events are at 200 kS/s. You are able to capture up to 9,999 waveform events. Depending on how you set your limits, you may get a lot or very few waveform captures.
Logging data of course uses a lot less memory. And that will depend on how you set your averaging time. The default is a 1 second averaging time. The range of logging intervals is 0.25s to 2 hours. If you log data every 2 hours, you will be dead long before you fill up an 8 gig card.
The best thing to do, is to set up the instrument with your configuration and let it run for an hour. That will give you a yardstick to estimate the duration that an 8G card will collect data.
11/07/2018 3:29 PM
It tells you on the start page menu how much time you have according to the sample rate you've chosen....
11/12/2018 12:27 PM
Yes. The equipment manufacturer will be happy to help over one of those under-utilised facilities these days - the telephone call.
Brave Sir Robin (1); lyn (1); PWSlack (1); redfred (1); SolarEagle (1)
