Previous in Forum: Time Travel Proof!   Next in Forum: Kilogram, Ampere, Kelvin and Mole Redefined International System of Units Overhauled in Historic Vote
28 comments
POD Changed to USPS in 1971
11/16/2018 5:58 PM
The USPS gets a lot of bad press,but there were,and still are some amazing employees at the USPS.
In 1988 they had a machine called the LSM(Letter Sorting Machine),
Which had 12 keyers,and 4 sweepers that removed the mail from the bins it was sorted into,and 1 supervisor.
The total output of the machine was 40000 pieces per hour.
The mail piece was moved through the machine in front of each keyer at the rate of one piece per second.In this one second,they had to remember the proper zip code,and key it via a very primitive specialized keyboard.
They had to know every zip code in the United States,and retrieve that info from memory in one second.
Some streets have multiple zip codes,depending on the address.
The machine sorted to a reject bin if no code was entered and it reflected which keyer station it came from.
The keyers had to key 99% or they would be sent back to retraining.
The previous machine required the use of foot pedals,like an organ,and the zip code had to be keyed in Octal format using pedals and keys.
These machines were eventually replaced by more advanced technology with machines that could read and sort at the rate of 40,000 pieces per hour with only one operator,and one sweeper.
Very little mail is hand sorted now,only if oversized or registered or certified mail.
Hats off to the ones that had such a demanding task and performed it so well.
Re: POD changed to USPS in 1971
11/16/2018 6:29 PM
And, yet, mail today is STILL miss sorted & miss directed ALL the time...because there are STILL people in the loop...called deliverers, who stuff prepackaged bundles into community mail (literally) BOXES incorrectly.
08/13/2019 6:12 AM
The USPS delivers over 500 million first class mail pieces every day.
Nothing is perfect,but the % error rate is very low.
Yet the squeaky wheel gets all of the press,as usual.
11/16/2018 7:46 PM
I agree. They do a great job, most all of the time. The insults being hurled at USPS in the last year are unfounded and childish.
I have found the desk agents are patient and helpful.
The mistakes are made by substitutes usually. The machines are almost always correct.
Think about it. For $.50 USD someone will deliver your letter almost anywhere in the USA.
11/17/2018 12:32 PM
You are correct about the substitutes.
They must learn a new route in one pass,and some rural routes are many miles apart,requiring many twists and turns.
I have had mis-routed mail,and it has always been a substitute carrier.
11/16/2018 7:53 PM
This post is some of the most hopelessly illiterate nonsense that I have ever heard.
11/16/2018 8:24 PM
This post is some of the most hopelessly illiterate nonsense that I have ever heard read.
11/17/2018 12:29 PM
"Ignorance consists not of what one does not know,but what one knows that just isn't so." -Abe Lincoln
Check your information sources to defend your statement.
11/17/2018 12:43 PM
Have you even been inside of a modern postal sorting facility?
Ever seen the machines they used in the 1970's?
A friend of mine,now in his 80's was there for 40 years,and saw it all.
He has photos of the old machines and the operators keying at 12 consoles.
And they did run at one letter per second,per console,and they had to input the zip code from memory.
Tis better to say nothing than to reveal one's own ignorance by accusing another of the same fault without facts.
11/17/2018 3:01 PM
What a load.
11/17/2018 3:48 PM
It is your prerogative to remain ignorant.
"You cannot reason a man out of a position that he has never reasoned himself into."
"Get your facts first,then you may abuse them any way you please."
-Mark Twain
08/13/2019 5:46 AM
You seem to be an expert on shit,so I have a question for you:What is the white stuff on the top of a chicken turd?
08/13/2019 6:05 AM
IF I wanted to insult or offend you,I might remind you that Washington is the home of Galloping Gertie,that was designed by Washington's best engineers,which might be an indication of the intelligence,education and literacy of Washington's finest.
I might also tell you an easy way to increase the average IQ of Washington and Mississippi would be for you to move to Mississippi.
BUT,I wont say that,because I don't want to offend your sensibilities.
08/13/2019 5:44 AM
Illiterate?
Please enlighten us with your brilliant knowledge of the system.
I am waiting to hear an intelligent post from you to with FACTS to justify your statement.
I will attempt to follow your brilliant narrative as best I can,because I realize that you have a superior intellect,far above this bottom dwelling pond scum's ability to comprehend.
The ball is now on your side of the net.
08/17/2019 12:15 PM
"Ignorance does not consist of what a person does not know,but what he knows that just isn't so" Mark Twain.
By that definition,you are the ignorant one in this forum.
Statements unsupported by facts are simply flatulence expelled under the internal pressure of ego to defend an untenable position.
Could you be persuaded to hover over Washington DC to suck up all of the flatulence in the area?Tornadoes suck,right?
"That's a joke son, a joke"
"That boy is about as sharp as a pound of wet leather."---Foghorn Leghorn
Re: POD Changed to USPS in 1971
11/17/2018 3:56 PM
Here is a link to some of the 1960-1970's MPLSM machines.
The early models only sorted 30,000 letters per minute,the later ones sorted 40,000 letters per minute.
https://postalmuseum.si.edu/systemsatwork/1968.html
And here is another one,with video.:
https://www.youtube.com/embed/p8sTsfUJAK8?rel=0
08/13/2019 6:21 AM
CORRECTION:
The early models only sorted 30,000 letters per minute HOUR,the later ones sorted 40,000 letters per minute HOUR per machine.
11/17/2018 4:08 PM
Here is a link to a more modern sorting system.
https://www.youtube.com/watch?v=WX16-52bHvg
11/17/2018 4:38 PM
6 days a week, at about 9:00 AM we get an e-mail with digital images of every piece of mail that will be delivered to our mailbox later that same day. No charge for this.
11/17/2018 9:32 PM
What? How do you sign up for this big-brother service?
So, the USPS now has a permanent record of you receiving being delivered a letter from Ed McMahon regarding your very likely financial future?
As I consider further, this scan and record technique must already be done on every delivery address whether you requested the email or not, is this so?
What happens if the Mail is stolen? Am I still on the hook?
This is, at first blush, disturbing. Can someone tell me to just go with the flow, have a sip of KoolAde and just trust the gubbumint, please.
11/17/2018 10:05 PM
Silly goose!
Actually they have a record of the piece being scanned by the OCR that routes it to your local post office.
Just like many most towns have traffic surveillance cameras on major intersections (not photo radar), license plate readers on police cars and the NSA/CIA/FBI/ Soviet KGB/GRU know what you bought yesterday.
If you have Windoze 10, Facebook. instagram, Ad nauseam you already have no secrets.
It'll get progressively worse now that a new regime is in power here.
Informed Delivery | You are now leaving USPS .com.
11/17/2018 11:34 PM
I thought that the " regime " that is now not in power, are the progressive ones.
11/17/2018 11:52 PM
I can explain it to you, but I can't understand it for you.
11/19/2018 4:10 PM
"... It'll get progressively worse now that...."
>>>. "... the " regime " that is now not in power, are the progressive ones ..."
Substitution using antonyms of 'progressive' doesn't really improve the outlook. Consider:
"... It'll get strictly worse now that...."
"... It'll get retardedly worse now that...."
"... It'll get dogmatically worse now that...."
"... It'll get stodgily worse now that...."
"... It'll get bigotedly worse now that...."
"... It'll get reactionarily worse now that...."
"... It'll get rigidly worse now that...."
11/18/2018 4:41 AM
It is even worse than you can imagine:
The ID Code,which is the orange fluorescent code on the back of the envelope tracks every image to it's final address.
The ID code records the machine number that processed it, month,day,time,and sequential mail piece.
All images are lifted and processed by computers,and non-readable images are sent to a central processing center where operators key-what-they see,with no zip code memorization required.They have whatever time it takes to process the letter.
However,they must achieve a standard number of letters per hour or face retraining at a lower rate of pay.
The info that they enter is processed by another computer,and the data is bound to the letter image data and sent back to the plant for second pass processing.
The images are deleted after 30 days....or are they?
Could they be stored forever in a giant data base that could be searched by name,address,etc?Or
Or a relational data base that could trace connections between any two people or group of people on the planet?
Can they read through envelopes layer by layer with laser without opening the letter?
The technology is available,and the question is:Are they using it yet?If not,you can bet that it is coming soon to a postal facility near you.
A little paranoia
Is good for ya'
11/19/2018 11:12 AM
It's not paranoia if they really are out to get you!
11/20/2018 11:40 AM
My girlfriend works there,
USPS is really pushing for automation, along with that are also problems.
Another item, the USPS it's technically not an government agency, and yet it is. There is a lot of confusion with this.
The only way the USPS can raise the price of a postage stamp is through an act of congress.
When you hear that the USPS service is losing money, that's is not really true. It actually is a profitable organization, if you can keep the politicians hands out of it.
I don't agree with the union organizational inefficiency, with the use of its employee resources. As an example, to cut costs the USPS will offer an cash buy-out to employees eligible some to retire early. Basically to get rid of the high priced seniority. What this does, people that were going to retire anyways, will sign up for it, and extend their employment and stay on for another 6 months to cash in.
Some interesting things about the automation of the USPS.
The USPS started a program about 2-3 years ago where they did a test where they will take a picture of every letter and with OCR, and if you what to know where it is, you could search for it if you know the address, they will tell you where its at... almost a tracking system.
An off shoot of that, you can know what's coming in the mail by signing up to have the USPS email what you'll be receiving with a picture of each letter, (they don't do packages yet, but they will let you know your getting a package).
This is great, if you expecting a important letter, and your gone for the day, you can manage you mail better and let someone know in your household??? to get the mail. (Also more importantly,... wondering if your get it in the mail today).
here's the link for that.
08/13/2019 5:31 AM
According to my friend who worked at a processing facility,it had only 2 of the LSM's,sorting 40,00 pieces per hour,required 17 people per machine,and total output per shift was 640,000 pieces.
10 Years later, the output was 40,00 pieces per hour and only required 2 people to run it,and 1 supervisor for all of the machines.
They had 15 machines when he retired,and less than 1/5 of the number of former employees.
So now they could run 600,000X8hours =4,800,000 pieces per 8 hour shift at less cost than they had been running .
How can they be losing money?
Gross mismanagement,politics,who really knows?
IMHO,it is propaganda fueled by certain businesses that want to get their hands on first class mail.
If they privatize,the low hanging fruit will be picked;places with high populations densities,and the suburbs and country customers will suffer.
The less populated areas will be contracted out to the lowest bidder,and mail will be delivered by the Avon lady or the Fuller Brush company salesman,or even Uber drivers(a real possibility).
No sanctity of first class mail, no postal inspectors,no way to know if your mail has been opened.
Once privatization becomes a done deal,there will be no turning back.
There will much B+G about the deliveries,and those who complain the most now will be the first to wish it was back the way it was.
08/13/2019 5:35 AM
Semantics,semantics,semantics.
When a person has nothing pertinent to add to the conversation,they revert to semantics.
My grandpa used to say." When you throw a rock into a pack of dogs,the one you hit will be the one that hollers"
Register to Reply 28 comments
70AARCuda (1); Doorman (1); HiTekRedNek (15); lyn (5); phoenix911 (1); tonyhemet (1); Tornado (2); Torqued (1); truth is not a compromise (1)
