Previous in Forum: What this is?   Next in Forum: Iron ore reduction
8 comments
gas injection
10/02/2007 7:05 PM
I'm trying to find a way to close the hole made by the gas injection needle in a plastic part. This part must come out of the mold without any hole! Can someboby help me with this issue?! Thank you!
Pathfinder Tags: GIT
Re: gas injection
10/03/2007 2:35 AM
Is the tool designed yet?
Can the injection needle be retracted and a sliding pin (like an ejector) push across to press the plastic over the hole...
Hmmmm that sounds pathetic..., but hey ya gotta have the bad ideas to get the good ones too.
Re: gas injection
10/05/2007 2:24 PM
Thak you for your cooperation!
We will use a Gunther System.
Re: gas injection
10/05/2007 3:58 PM
Presumably ..so called 'cos that's gunther do for now?
Re: gas injection
10/03/2007 3:39 AM
Which plastic?
ABS, PVC and polystyrene can be sealed by sending in a tiny globule of semi-dissolved plastic held in a solvent such as 2-butanone/butan-2-one (call it MEK if desired - it's the same stuff) for polystyrene, though ABS/PVC pipe cement would do the job for all three of them.
If the part is polyethylene or polypropylene, sealing the hole with some sort of heat device like a soldering iron (or maybe something more elegant) would do.
Other plastic? Others can chip in....
Does that help?
Re: gas injection
10/03/2007 6:25 PM
use vacuum to mold the part then you have a projection on the outside of the part no hole
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
Fans of Old Computers - ZX-81 - New Member Popular Science - Cosmology - New Member United States - Member - New Member APIX Pilot Plant Design Project - Member - New Member
Re: gas injection
10/04/2007 8:29 AM
ok, here's an idea, but can I have a piece of the patent?
design the needle injection/retraction point through essentially a hot runner area - sequence the activity so that the needle is retracted through hot plastic after the gas injection then freeze the aperature -
Jim
-opinions free; worth twice the price -
Re: gas injection
11/01/2007 4:47 PM
just wondering - how did this ever work out?
Jim
Good Answers: 266
Re: gas injection
10/04/2007 4:13 PM
Heated needle as the needle is with drawn the melted plastic will be force into the hole vacated by the needle. Should reseal itself if the internal pressure of the injected gas is not to great. Temperature of the needle will need to be controlled if too cool the plastic will not become tacky to hot and it will scorch the plastic. You didn't say what gas hope it's not flammable.
Register to Reply 8 comments
coconutpete (1); eagertask (2); mike molds (1); ozzb (1); PWSlack (1); user-deleted-1105 (2)
