Previous in Forum: transmitter   Next in Forum: Change shaded pole motor to another?
Engineering Fields - Control Engineering - New Member
Looking for a switch panel
10/03/2007 6:39 PM
I'm looking for a wall mounted pushbutton switch panel. I need 4 momentary dry contacts going to 4 dry contacts on a BAS. The sticking point seems to be that I can't have illumination; I don't want voltage feeding back into the BAS controller.
Has anyone seen such a beast?
Let me know.
Thanks
John
jlfiegel
Good Answers: 18
Re: Looking for a switch panel
10/05/2007 8:33 AM
What's a BAS?
Look for pendant with four switch mounting holes and four dry contact industrial-type switches in a Grainger catalog.
10/05/2007 1:49 PM
Thanks.
BAS=Building Automation System.
John
jlfiegel
10/05/2007 9:59 AM
Is it fair to assume that you mean Building Automation System when you say BAS?
I would suggest looking at a wireless remote option. You could use a hand held transmitter or a stationary transmitter. I am not sure where you live but I know that different supply houses will have the options available, for example CED or Kaman. I know that there are manufactures out there like Remote Control Technology, TRC, and various others that may be able to help.
Good luck with your search.
10/05/2007 11:32 AM
Thanks. FWIW, I am in California, SF Bay area.
John
jlfiegel
United States - Member - Les Etats Unis
10/05/2007 12:21 PM
This should be very easy to build your self. Pick out a panel surface you want, metal plastic or whatever. Purchase momemtary pushbuttons or switches from a supplier like newark or mouser or some other electronics supply. Once you have the dimensions drill holes in the panel or have a machine shop do it for you. mount the buttons. get a wall mounted enclosure or box or some other method of mounting this to the wall. Run your cables, solder them to the appropriate leads. Install/mount contraption to wall. There is also probably turn-key set ups you can buy also.
No trees or ecological systems were harmed in the creation or transmission of this message. However, a large number of electrons were horribly inconvenienced.
01/17/2008 2:59 PM
Try www.barantec.com --- they have dry contact piezo switch panels - very rugged.
Register to Reply 6 comments
Anonymous Poster (2); Bill (1); Electron Oasis (1); jlfiegel (2)
