I know that efficiency of shaded pole motor is very bad. So I want to use senkron motor instead of shaded pole motor. Do you think that cost of the senkron motor (aprox. 10-30 watt 1500-2000 rpm) will be more much than shaded pole motor.
Usually shaded pole motors are used in very low HP applications like condensor or evaporator fan motors for domestic refrigerators/freezers. I don't think there would be much savings benefit from replacing such a motor.
