Previous in Forum: Change shaded pole motor to another?   Next in Forum: for job
Portable Chlorine Gas detector in Water or Environment
10/05/2007 3:22 AM
Kindly sent the details of chlorine gas detection in water or environment (in ppm)
Location: Saudi Berkefeld Filter Co- Riyadh - Saudi Arabia
Re: Portable Chlorine Gas detector in Water or Environment
10/06/2007 5:56 AM
Portable chlorine gas detectors
Water - Residual Chlorine Analyzer cell,
Environment - Chlorine Gas Leak Detector,
These are available with chlorination system mfgs like Jesco, Enviro system, Capital control..........
Rgds
Ayub A Ismail
Ayub
Good Answers: 101
10/07/2007 9:19 PM
What exactly are you asking for? A means to measure chlorine levels in water, or the actual levels present in water? If you're looking for the actual levels, enquire with your local authorities since different regions have different quantities. If you're looking for meters that measure chlorine levels, write to companies such as Lovibond or Hach; they manufacture such meters.
You might be interested in: Gas Sensors, Gas Generation Equipment, Gas Instruments
