Previous in Forum: Flyback Oscillator Operating Frequency   Next in Forum: general
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
xlpe cables
10/05/2007 7:33 AM
The differance between xlpe (e ) and xlpe i.e earthed and unearthed and recommendation for it's application
nascon
Re: xlpe cables
10/05/2007 7:54 AM
Xlpe is "cross-linked polyethylene", and cannot be earthed, as it is an excellent insulator.
Xlpe has a different dielectric strength compared to other insulators like PVC, and this characteristic can be used to alter the characteristics of the cable compared to other insulation types, which can be of distinct advantage at higher frequencies.
Re: xlpe cables
10/05/2007 8:33 AM
Thanks,
The question is the application of xlpe cable use on earthed / un earthed system
nascon
Egypt - Member - Ahmad Samak
Re: xlpe cables
10/05/2007 7:07 PM
What I can say is no difference; the use of XLPE cables is not dictated by the system whatever it is, XLPE cables are used in grounded and isolated/ungrounded systems.
For ungrounded system,the cable voltage-rating may be affected as, for these systems a single-line-to-ground fault causes the cable phase-insulation will be subjected to line voltage instead of phase voltage (i.e. 173% over-voltage).
Consequently, you may be forced to increase the voltage rating of whatever your cable is.
Good Luck... Samak
Re: xlpe cables
10/06/2007 12:06 AM
thanks
nascon
Re: xlpe cables
10/06/2007 11:59 AM
Unearthed cable has increased insulation
Re: xlpe cables
10/08/2007 8:37 AM
If yo use any equipment in an ungrounded neutral system you need to use full insultion say phase to phase insulation even for phase to neutral connected loads.
Regards
Register to Reply 6 comments
Blitz (1); elbf2801 (1); nascon (2); PWSlack (1); Samak (1)
