Previous in Forum: Heat Pump Rant   Next in Forum: Engineers Translate Brain Signals Directly Into Speech
How to Repair the Seal on the Shut-off Valve of a Steam Radiator with a One-pipe System
01/30/2019 9:56 AM
Exactly how do you clean or repair the seal on the shut-off valve of a radiator with a one-pipe steam system?
Re: How to Repair the seal on the shut-off valve of a steam radiator with a one-pipe system
01/30/2019 10:22 AM
This might be a mechanical seal gate valve....in this case it can usually be cleared by opening and closing the valve, flushing it while open to remove any debris....
This is the air valve...
Re: How to Repair the Seal on the Shut-off Valve of a Steam Radiator with a One-pipe System
01/30/2019 11:03 AM
Thank you very much for the two videos.
01/31/2019 8:38 AM
Dear judith:
You don't, or, your are under a lease agreement, as per your earlier response.
If you take it upon yourself to service or repair a valve on a piece of equipment that you have not been contracted to, and injury or damage occurs, you maybe held liable for any and all claims arising thereof.
Contact your leasing agent/landlord/property owner, etc before proceeding.
02/02/2019 11:22 AM
One would start by phoning the friendly local valve distributor to obtain a seal repair kit. One then follows the instructions supplied with it when it arrives.
02/02/2019 8:57 PM
hello is this the valve distributor?
I'm looking for a seal and an instruction kit for my valve.
Radiator...
Yes one pipe.
02/03/2019 2:15 PM
No, I am not the valve distributor.
Register to Reply 6 comments
JE in Chicago (1); Judith Potter (2); PWSlack (1); SolarEagle (1); tonyhemet (1)
