Previous in Forum: Scientists Develop First Fabric to Automatically Cool or Insulate Depending on Conditions   Next in Forum: How to Get Rid of Gophers
28 comments
What Is It?
02/08/2019 7:46 PM
Re: What Is It
02/08/2019 8:30 PM
Looks like some kind of clock that shows the day of the month...
Re: What Is It
02/08/2019 8:40 PM
It does indicate days, but not time.
Re: What Is It
02/08/2019 9:54 PM
Some type of flow meter? Or timer powered by flow.
Re: What Is It
02/08/2019 11:14 PM
Birth control pill dispenser...
Re: What Is It
02/08/2019 11:58 PM
You lost the mood trying to get it to dispense... ya,.. I guess it works...
Re: What Is It
02/11/2019 12:46 PM
I didn't work for Lyn's mother.
Re: What Is It
02/11/2019 7:32 PM
That's low life, rude and an insult to my mother!
Re: What Is It
02/09/2019 6:14 AM
Your mission, should you choose to accept it is to …...
This message will self destruct in five seconds
Re: What Is It
02/09/2019 9:24 AM
Jim,.... is that you?
Re: What Is It
02/09/2019 11:05 AM
Re: What Is It
02/09/2019 10:38 PM
A string or cord (cord may include wire) must pass through that hole. Now is it to wind the thing up, or does the thing wind up the cord?
Re: What Is It
02/09/2019 12:44 PM
Re: What Is It
02/10/2019 9:20 AM
Moving the cover (lower left post #9) drives the gear train (Shown in post #2) to advance two foil strips (left center #9) while removing the cover strips (middle row, left side #9) which then allows the user to inhale the different powders through the mouthpiece (top row, left #9) into the lungs. The dial in the bottom picture of the original post indicates the number of doses remaining in the contraption.
It's not automatic, but it seems to be overly complex and is probably one reason for the high cost of the drugs inside.
While it is not automatic, it does dispense medication, Tony.
Re: What Is It
02/10/2019 10:50 AM
Lyn, can you provide some more details.
A. Physical dimensions / in operation mechanical diagram-video
B. Unfilled dispenser cost / refillable / single use
C. Composition / plastic types / recyclable
Thanks
Re: What Is It
02/10/2019 1:40 PM
Tony,
Not sure why you would want all these details, most of which I don't know.
I'll PM you with the name and you can take it from there.
Re: What Is It
02/10/2019 10:50 PM
Thank you.
Re: What Is It
02/09/2019 6:52 PM
Day reminder for those with oldtimer's disease...
Re: What Is It
02/09/2019 7:20 PM
It looks like there is a little swing cover for a hole that you could load or unload something!?!
It also looks like the kind of apparatus found in a gas meter.
looks like, but aint it.
complex and cheaply made?
Re: What Is It
02/10/2019 1:32 AM
An automatic medication dispenser ?
Re: What Is It
02/11/2019 6:43 AM
Accuhalers seem to do the same job with much less complexity...
Re: What Is It
02/11/2019 10:27 AM
True. I took one of those apart a year ago and there are only 10-15 moving parts in them.
Re: What Is It
02/11/2019 1:09 PM
maybe less
Re: What Is It
02/11/2019 9:26 PM
JE, thank you for the cutaway. It's easy to see the mechanism operation. I gave you a good answer
Re: What Is It
02/11/2019 10:41 PM
Thanks Tony
I know why you would want to know these things.
There are engineering minds and there are crankshafts.
And you know what they say about crankshafts?
What goes around comes around.
Re: What Is It
02/12/2019 9:15 AM
Some are content to pretend other people don't exist.... With the exception to pm them. Calling them insensitive jerks etc.
That's not what I love about this place.
That's what I loathe about this place.
What a gigantic load.
-later
Re: What Is It
02/12/2019 11:55 AM
It's OK. Accidents happen, in this case a fortunate one.
Re: What Is It?
02/12/2019 8:20 AM
Certainly seems, mrs. has got this to avoid impregnated?
Re: What Is It?
02/22/2019 2:29 PM
very interesting thing
Register to Reply 28 comments
dkwarner (1); gutmonarch (1); JE in Chicago (4); JohnDG (1); Jpfalt (2); Just an Engineer (1); Kenannar6 (1); lyn (7); phoenix911 (3); Rixter (1); SolarEagle (2); tonyhemet (4)
