Previous in Forum: using emulsion in pumps will reduce the energy consumption in pumps?   Next in Forum: couplings
reg using of emulsion in cooling water line
10/07/2007 10:08 AM
i am going to study the detail flow analysis in cooling water pump when i used emulsion as an cooling water . emulsion in the sense (water + oil) so that oil will form as an thin coating agent so that the frictional losses are reduced . i also want to prove this by using analysis in cfx. please advice me reg this
Good Answers: 19
Re: reg using of emulsion in cooling water line
10/07/2007 3:10 PM
Pasting below an abstract, perhaps you contact them to help you out:
Experimental research on laminar flow performance of phase change emulsion
Binjiao Chena, Xin Wanga, Yinping Zhanga, , , Hui Xua and Rui Yangb
aDepartment of Building Science, Tsinghua University, Beijing 100084, China
bDepartment of Chemical Engineering, Tsinghua University, Beijing 100084, China
Received 4 January 2005; accepted 10 October 2005. Available online 15 December 2005.
Abstract
Phase change emulsion (PCE) is a kind of novel heat transfer fluid with greater apparent specific heat and stronger heat transfer capacity than water. The laminar rheological characteristics of a type of PCE developed by us were experimentally studied. And the advantage of applying this kind of PCE as a heat transportation fluid was discussed. The results show that: (a) its viscosity is about 5.57 times of that of water, which is much lower than those reported in the literature; (b) it can be considered as Newtonian fluid from its rheological characteristics and its friction factor conforms to the rule of 64/Re; and (c) for given heat transportation quantity, due to which greater apparent specific heat, the mass flow rate and the pump consumption for the PCE decrease greatly compared with water.
You might be interested in: Cooling Tunnels, Electronic Cooling Fans
