Previous in Forum: Use Of Diversity Factor   Next in Forum: Switch Versus Isolator
20 comments
Breaker Sizing
10/09/2007 1:22 AM
What is the sizing calculation of main incommer of MCB or MCCB breakers?
manirul
Re: breaker sizing
10/09/2007 3:47 AM
Refer to the local Wiring Regulations applicable to the country of use.
In the absence of a local standard, use the Institution of Electrical Engineers' current edition of the Wiring Regulations applicable in the UK as a guide to good practice.
Re: breaker sizing
10/09/2007 4:37 AM
Incomming circuit breaker. Pls give some more in formation about: phase, rated current, protection type, voltage,etc.
Re: breaker sizing
10/09/2007 4:50 AM
i dont think all those info is required to get calculatation procedure, i have not ask for rating of breaker, what i want to know how to calculate not the resulte of calculation, any way the info is as below
phase :3
rated voltage: 440
rated frequency: 50 Hz
Rated current: 800 A
manirul
India - Member - New Member
Location: India - (Home town - Tamil nadu, Working - Jemshedpur)
Re: breaker sizing
10/09/2007 10:11 AM
Dear manirul,
MCCB & MCB are basically used for Short circuit protection. MCB for Low rating & MCCB for High rating. For selection, two factors- Short circuit rating (KILO AMPERE) & Over load rating (AMPERE) are to be considered as mentioned below:
Short circuit rating (KILO AMPERE): Measure the resistance of outgoing busbar or cable, i.e., resistance from the point of MCCB outgoing termination to the distribution load switch gear(s) & calculate the max current it (busbar or cable) can withstand. Now refer the standard chart of MCCB manufacturers & select the short circuit rating (KILO AMPERE) matching more or less to your calculated figure. Finalise that as Short circuit rating (KILO AMPERE).
Loading capacity (AMPERE): Sum up distributed load currents (max instantenous current) which can flow through MCCB. Multiply the same with 1.5. The is the over load capacity of MCCB. Note: If you have more no of high rating motors with distributed load & if they start simultanously, considering their starting current, increace this rating to some more %. Now refer the standard chart of MCCB manufacturers & select the loading capacity (KILO AMPERE) matching more or less to your calculated figure. Finalise that as loading capacity (AMPERE).
Regards,
Vinod.P (Asst Mgr-Engg),
SCJPPL, HP,India.
Email Id- vinod29mar@gmail.com
Regards, Vinod.P, Engineering Deptt, LAFARGE , India
Re: breaker sizing
10/10/2007 12:24 AM
Thanx Mr. vinod
I appreciate ur effort to put the light from technical point of view and that's prove ur tecnitiality while other people just have an argument to kill the time. ur shareing of Knowledge will be gr8 help to me.
manirul
India - Member - PROFESSIONAL Engineering Fields - Power Engineering - electrical planning - designing
Re: breaker sizing
10/10/2007 2:41 AM
Is it clear you can not have MCB
The batter alternate is Air Circuit Breaker for the rating of 800 Amps.
nascon
Re: breaker sizing
10/09/2007 6:18 AM
Dear
As the breaker names indicate , The MCB is miniature Circuit Breaker., i.e breaking capacity limited for short circuit / fault level .
MCCB i.e Moulded case Circuit Breaker., not limited to miniature SC.
The MCB sizing is limited up to lower short circuit / fault level say @ 63 Amp., due to product designed limitation of short circuit level / fault current @ 10 KA recently available on request for 80 / 100 Amp.
The MCCB sizing for the fault level are for higher breaking capacity ., i.e short circuit for more than 10 KA and up to 143 KA amp rating up to 1600 Amp.
nascon
Re: breaker sizing
10/09/2007 6:39 AM
Dear
you are talking about difference B/W MCB and MCCB, but discussion is not intendent to that.
manirul
Re: breaker sizing
10/09/2007 7:35 AM
Dear
Breaker sizing , if not discreamination of falut ? not amp and SC ? what do youmean over all dimension?
nascon
Re: breaker sizing
10/09/2007 7:43 AM
dear
breaker sizing is not fault calculation but it definitely amps but not SC
manirul
Re: breaker sizing
10/09/2007 8:03 AM
Dear
You must know the basic, when you are sizing the breaker with Amp ., it is rate Amp. And, the said rated amp must withstand the required SC / Falut current for the system it is connected to.
Hope, you will understand the what the sizing of breaker means ?
nascon
Re: breaker sizing
10/09/2007 8:16 AM
exactly, now the question is if you are saying withstanding, then it is not only SC but also time which is relavent, am not sure about it.
manirul
Re: Breaker Sizing
10/09/2007 11:09 PM
What's the load on the circuit? FTLOG, without that all questions are meaningless!
If all else fails, read the directions. That's if, and only if.
Re: Breaker Sizing
10/10/2007 9:59 AM
What is the criteria in selecting ACB, MCCB, OCB, VCB etc. in both LT & HT distribution. In other words, how is the / in what basis the selction of breaker is made? can some one explain??
Re: Breaker Sizing
10/11/2007 4:25 AM
HT , two more type of breakers are available i.e MOCB (Minimum Oil Circuit Breaker ) and SF 6 (Sulphur Hexa Fluoride)
nascon
Re: Breaker Sizing
11/16/2007 8:25 AM
MCCB & ACB are used in LT side. MCCB for low rating (It is safe upto 400 Amp) & ACB for more than 400 Amp.
OCB: OCBs comes just above ACB for highier rating. Earlier days it was used both in LT & low level HT side. Later it was used only in low level HT side. But now days OCBs are slowly getting replaced by VCBs. This is because of OCBs need more maintenance, maintenance cost is high & not environment friendly.
VCB & SF6: These are used in HT side. They is more relaible & efficient. For some special applications like very high making & breaking currents, VCBs are also used in LT side.
Note: The above said are the classifications & some what related to selection also. Other than this, selection includes Breaking capacity, Short circuit current, Load current capacity, Earth leakage current level, No of poles required, Protections required, Voltage level etc.
Regards,
SCJPPL, HP,India.
Re: Breaker Sizing
11/16/2007 8:51 AM
thanks vinoth,
though it was posted long back, you have replied with some valuable datas.
Technical Fields - Technical Writing - New Member India - Member - New Member
Re: Breaker Sizing
04/14/2010 2:36 AM
For calculating Breaking capacity of CB downlaod excel base program from
www.jiguparmar.com
jiguparmar
Good Answers: 164
Re: Breaker Sizing
04/14/2010 11:34 AM
Superb website....hats off to you Jiguparmar.
Good Answers: 164
Re: Breaker Sizing
04/14/2010 11:43 AM
Ok...having seen and studied the replies, may i mention that you need to look at circuit breakers in series mode...discrimination and cascading. An excellent paper on this is available from Schneider, please visit ...
http://www.schneider-electric.com/documents/technical-publications/en/shared/electrical-engineering/dependability-availability-safety/low-voltage-minus-1kv/ect167.pdf
Register to Reply 20 comments
haivot (1); jiguparmar (1); ktel60 (1); kvsridhar (2); manirul (5); Minsaramanithan (2); nascon (5); PWSlack (1); winotp (2)
You might be interested in: Circuit Breakers, Load Centers
