Previous in Forum: Harmonic Analysis   Next in Forum: Leakage Current Measurement of 400kV Surge Arresters
10 comments
Sensors
03/27/2019 11:24 AM
Is there any such sensor which would detect only specific materials that are to be found out , because i need a sensor that would seperate debries(metals,glass,stones,etc) from the rubber material for me
Pathfinder Tags: sensors
Re: Sensors
03/27/2019 11:46 AM
  • The buoyancy of <...rubber...> is different to the others.
  • The combustibility of <...rubber...> is different to the others.
  • The solubility of <...rubber...> in organic solvents is different to the others.
These factors suggest the separation techniques that could be used.
Good Answers: 146
Re: Sensors
03/27/2019 4:44 PM
Mechanical separation should be easy assuming the rubber is hardened. Float off the rubber, stones glass rocks fall to the bottom. No sensor needed, just a tumbling or shaking process. Check results and adjust length of process, more or less done, from the sound of it.
incus opella
Re: Sensors
04/03/2019 10:43 AM
Quite. Sensor-less operation is the aim.
Re: Sensors
03/27/2019 12:23 PM
Re: Sensors
03/27/2019 12:25 PM
There is no indication yet of the flowrates of the various components nor of the particle size ranges of each component. These data might suggest further opportunities.
Re: Sensors
03/27/2019 1:28 PM
The waste stream would have to be studied carefully to identify characteristics that could be targeted for separation...size, shape, weight, molecular density and other characteristics come into play...
Re: Sensors
03/28/2019 12:43 AM
Basically, we are all suggesting with the lack of details on the size & variability of the feed, it is unlikely to find an instrument to detect the difference. So mechanical separation methods have been proposed.
However, IR spectrum absorption might differentiate, expensive but non-contact instrument, using FTIR methods. Hand held units are used at recycle centers to verify alloys, for instance.
Vision systems can be programmed to identify chacteristics such as color, reflectivity, shape, and at speeds up to 40mph. The most elementary of these can be purchased for under $2,000 US. Telemecanique Vision OSI-XUW, for instance.
A cyclone separator would be a more conventional solution, not the cheapest solution if you consider operating cost, compared to a classifier with drop gates actuated by your sensor.
Re: Sensors
03/29/2019 6:59 AM
What colours are present in the mixture?
Re: Sensors
03/30/2019 1:10 AM
Rubber being black , cast iron or steel penetrated inside the rubber (grey or silver colour) and other debries like stone glass of their respective colours.
Re: Sensors
03/30/2019 12:53 PM
So you need to reject rubber & metal when combined, for further processing, but if uncontaminated rubber, that goes to your accepts?
You could screen for any metal using radio frequency or pulse induction, but you’d need other instruments to sort glass or stone, probably density would be a mass sort method, if reflectivity or shape would not be reliable.
Register to Reply 10 comments
artsmith (1); Brave Sir Robin (1); pratik000.marathe (1); PWSlack (4); rwilliams (2); SolarEagle (1)
