Previous in Forum: The Least Radioactive Radioactive Element (Known) Xe124   Next in Forum: 10-56 UNS Tap
28 comments
Beyond Our Visible Universe
04/30/2019 8:44 AM
Our knowledge of the universe is limited to the visible portion aided by most sophisticated receivers at all frequencies. There is much beyond this limited view. A common thread of nature is balance. Nature always seeks balance. Water flows downhill. Mountains are eroded flat over time; even tiny hills are eventually leveled. Heat flows to cold (with some recently discovered exceptions on the quantum level). Gas will expand until it is dispersed in all directions. The (visible) universe is expanding. Into what? It seems to me that nature is seeking balance on the largest scale, expanding into a region of unknown dimensions which has less energy. Some say there is nothing outside of our universe to expand into, that spacetime is created as it expands; but that is only our visible, detectable universe. Man used to think that the earth was the center of the universe. Then it was the Milky Way, then the Milky Way was discovered to be one of billions of galaxies, thus reducing mankind to a tiny spec in a vast ocean of reality. Yet we still cling to the notion that the universe consists only of that which we have knowledge of. Baryonic matter is only around 5% of our known universe. I think time will reveal that our visible universe is only a tiny spec of reality, and that our universe is influenced by "outside" forces, thus far undetectable by mankind. If we had an "infinite long view" maybe we would see that our visible universe is only one of billions, like our galaxy.
Pathfinder Tags: A long view of our universe
Re: Beyond our visible universe
04/30/2019 9:33 AM
No, our knowledge of the universe extends much farther than the visible. As far as light, we know that the visible spectrum is but a very thin part of the total spectrum. I for one know much more about how solid state devices work at an atomic level than I did when I was given my first transistor radio. None of that knowledge came from seeing electrons flowing.
Water flows both downhill and uphill (how do you think it got to the hilltop in the first place?). Mountains both erode and are formed over time (it seems you forgot about the recent eruption at Kilauea). Heat does regularly flow out of something cold into something hot (it won't do this without assistance but my beer still gets chilled). It is only an observer's perspective that deems if expansion must be into something else. I've heard many an orchestra create wonderfully expansive sounds in a hall with fixed spatial dimensions.
As for the center of the universe, I and my wife are the centers of our universe and we are fine, thank you very much. It seems to me that your universe is distracted with far too many mixed metaphors and incomplete frames of reference. I think you need to regain your center.
04/30/2019 11:56 AM
Everyone is the center of their own personal universe.If you die,for all intents and purposes,your universe dies.But everyone else's continues.Mountains do arise,by tectonic plates and volcanic action,but even these forces are a result of nature trying to achieve balance.Tectonic plates move in the direction of least resistance,lava flows in the path of least resistance,as does water.Water gets to the top of the hill by rain,which is water vapor initially,and the vapor is created by unbalanced forces.Your beer is cold because a refrigerant was used to remove the heat from the beer,and expel it elsewhere.The air in the refrigerator has had the heat removed by a refrigerant that is much colder than the air. The heat will dissipate into the cooler surrounding outside air via the condenser coils and fan. Weather is also a result of balancing forces.Hot air rises from the equator (both directions; Hot moving towards cold),Coriolis effect imparts a rotation to the air which create the jet stream and winds.High pressure centers move toward low pressure centers.The low pressure centers are created by water vapor,which is lighter than dry air. Outside of our personal internal universe there is much to be learned,but you must think outside of the constraints of personal experience and try to be objective about a larger whole. It is true that my personal universe would collapse into chaos without my wife,but on this particular topic of interest,my original posting, I am speaking of a larger picture.
04/30/2019 2:27 PM
I am speaking about a more accurate picture than an incomplete feeling.
Water vapor is water.
Tectonic plates move after resistance has been broken down. When this happens it's called an earthquake.
Lava moves up first to reach the Earth's surface. Once there it may solidify in place and thus not move up or down. It may form a lava tube to move downrange of the volcano. Lava may even erupt up into the air once it reaches the surface. Lava does not always go down.
I certainly know and understand the laws of thermodynamics and entropy. I also understand many of the cosmologic predictions for planets, stars, and the whole universe. After more than 13 billion years of constant, very dynamic activity always happening somewhere since the start of the universe, I think it is pure hubris to think balance to be normal or to even anthropomorphize the universe as wanting to achieve a balance. The change of things appears to be the constant not equilibrium.
04/30/2019 5:17 PM
04/30/2019 6:25 PM
Water vapor is a gaseous form of water, and is lighter than dry air,that's true,just as ice is the solid form.Liquid water does nor flow uphill without an external force,and the force has to be greater than the resistance to the flow. When I spoke of water not running uphill,I was referring to LIQUID WATER,and I thought that most anyone would know my meaning.If I had meant water vapor,or ice,I would have said Water Vapor, Steam or Ice. When a tectonic plate moves,it moves in the easiest direction.When lava flows,it flows in the easiest direction.If the surface above it is weaker than the forces below,it will erupt or flow out of the crust.Lava is constantly circulating in the mantle,similar to wind or tides on the surface,but always the motion is in the direction of least resistance.Heat flows,cold does not flow, it is merely the absence of heat,(molecular motion),however there are some instances on the quantum level that the flow is reversed,but not in the macro world in which we live. As Mark Twain said:"Knowing exactly the right thing to say,I said nothing." So I will stop arguing my point now.
04/30/2019 9:22 PM
Liquid water most certainly can and does move up without an external force.
That drop comes up out of the pool without any external force.
04/30/2019 9:37 PM
A rubber ball will also bounce. The surface tension of the water is like a spring and part of the drop springs back from the energy stored in in during the fall. More is the pity that you do not see or understand the forces acting on the water drop.If you don't understand it,you probably never will.
05/01/2019 5:48 PM
05/01/2019 1:32 AM
Can you show a video of a drop of water coming up, out of a pool, without a drop, first being dropped into that pool
Or,
Show an action created on it's own, without any type of precursor activity.
Re: Beyond Our Visible Universe
04/30/2019 10:55 AM
Current thinking, AFAIK, is that the universe isn't expanding into anything. Space itself is expanding. The classic example is that it's like spots on a balloon that is being inflated. If you put spots on the balloon and inflate the balloon, the spots become further apart, yet the spots are not moving with respect to the balloon.
If distant galaxies are receding, the frequency of light emitted is shifted to longer wavelengths due to Doppler shift. If space is expanding, the wavelength is lengthened due to the expansion of space during the time since the light was created. It looks a lot the same.
There is a difference between space expanding and distant galaxies just moving away. Distant galaxies could not move away faster than light speed, due to relativity. However, if space itself is expanding, at some distance, the event horizon, light emitted could never reach us because space is expanding faster than light.
04/30/2019 11:32 AM
My point exactly: current thinking is the problem I see. If natural laws apply universally, then the universe is seeking equilibrium; with what, I do not know.
05/02/2019 1:24 AM
God.
05/01/2019 8:27 AM
Seems interesting to compare the Universal event horizon to the event horizon of a black hole.
04/30/2019 11:48 AM
Today my visible portion of the universe consists of looking down while mowing the front and back yards.
I won't have time to look into the heavens and contemplate what's beyond that.
Please let me know if any revelations become apparent. I don't want to miss any of the good stuff!
04/30/2019 12:41 PM
The comments recall the words of Leonard Cohen - "We are so small between the stars, so large against the sky..." (From "Stories of the Street")
04/30/2019 11:23 PM
There was no question here. What is it that you want is to take away from this preaching? That the universe is unbalanced? Some people who post here are, and you may not be exempted from that list.
05/01/2019 8:56 AM
Thanks for the compliment.I have never been considered to be "balanced" or "quite all there." I used to be offended when I was a kid,but then,one morning,before sunrise, as I sat there eating walnuts and reading a book titled"You are what you eat" it dawned on me. I guess I am just a little(or more,depending on who you ask) crazy.If a person is rich and crazy,they call him "eccentric". If he is poor and crazy,they call him "crazy'. I am not rich in material things,but I am blessed with the important things that money cannot buy. This original post was not posed as a question,rather as a discussion. It has generated many questions and opinions,which was the purpose,after all. I gathered a lot of information and insights in this discussion,so it has served the purpose quite well. Many thanks to all who contributed!
05/01/2019 2:35 AM
Is there an end to the universe? Can "nothing" be defined? Is it worth the thought?
05/01/2019 7:04 AM
Yes. It can be defined as the point where everything in the universe has decayed into low-grade hear and it is all at the same temperature.
05/01/2019 5:46 PM
hear heat
05/04/2019 12:45 PM
Empirically speaking, the first iteration of your comment might have more backing than the correction you provided.
In my lifetime, I haven't perceived the quality of the heat degrading appreciably. On the other hand, the quality of what I hear has definitely degraded significantly.
06/11/2019 10:08 AM
05/01/2019 8:33 AM
whether our universe is but a minuscule sub particle of some grander universe or the one of many universes in this space time. We are but infants in the grander scale of things, that as our expansion in to the unknown may revile, at a different point in our time space. The wonders of dreams that may be found,
05/01/2019 10:43 AM
"Our knowledge of the universe is limited to the visible portion aided by most sophisticated receivers at all frequencies." The ultimate limit to our knowledge of the universe is about 50 billion light-years; beyond that the known universe is expanding FTL and we won't be able to see further until someone invents the warp drive. "Baryonic matter is only around 5% of our known universe." That notion is based on the theories of dark matter and dark energy, both just SWAGs invoked to explain the otherwise inexplicable. We might find that gravity isn't quite as described by Newton and Einstein. And we might find proof of the multiverse. I for one doubt our species will survive long enough to know all the answers. But it sure is fun to try.
05/01/2019 3:30 PM
Whether <...the universe...> were <...one of billions...> cannot be determined, as any information about such a thing would need to travel faster than light in order to convey it here. Therefore the prospect can have no consequence here.
Further, if such a thing were known about, then <...one of billions...> would have simply become another part of the <...one...> after having revealed its existence. Therefore <...one of billions...> would be simply the wrong term to use.
This thread is such a brainfart on so many levels...
05/01/2019 4:47 PM
The concept of infinity has always been intriguing.
05/01/2019 5:51 PM
<yawn>
<unsubscribes>
05/02/2019 3:57 AM
Flatulence ,whether mental or bowel in origin,usually results from the lack of proper culture,and hence indigestion, of nourishment that is presented to it. For flatulence originating in the brain,try a good yawn. For flatulence in the bowels,try a good laxative. Sometimes both maladies go hand in hand. By the way,after a certain age,farts are not to be trusted.
Register to Reply 28 comments
Anonymous Poster (1); canadianslidewinder (1); cblm46 (1); HiTekRedNek (7); lyn (1); PAPADOC (2); PWSlack (5); redfred (3); Rixter (1); SSCpal (1); StandardsGuy (1); tonyhemet (2); truth is not a compromise (1); WI Mike (1)
