Previous in Forum: Diecast Quality - ASTM e505 Spec   Next in Forum: Injection Machine Mold Testing
13 comments
Injection Molding Machine Clamping Position Varies
05/30/2019 6:39 AM
clamping position not reach to its final (zero) position.i.e to its full tonnage location where high pressure will lock the machine. it stop at random position of 8 to 3mm but machine start to inject the material.
this is not constant error and occurred some time during process cycle. we suspect linear position scale and change with new one even done with zero setting within machine setting.
now i need to know which are the possible reasons for this problem.
Re: Injection molding machine clamping position varies
05/30/2019 7:07 AM
CR4 is the wrong location to search for <...the possible reasons...>. The correct source of this information is the Service Technician, "Anonymous Poster #2", who is investigating and clearing the fault. After all, the equipment cannot be seen from here.
05/31/2019 11:32 AM
On a properly set and maintained Injection moulding machine, the injection unit will not move forward and engage with the fixed mould side and start injection if the mould is not closed and the correct clamping pressure is not reached. What make and year model machine is this? The fact that injection takes place tells me that some safety systems are not working. Get the manufacturer to repair this first.
05/30/2019 7:18 AM
Several possibilities come to mind in no particular order:Hysteresis in the mechanical portion of the clamp,noise in signal from position transducer,electrical noise from recently installed new equipment,such as variable frequency drives,dirty electrical connections in signal wiring,loose connections.Intermittent problems are the worst kind to troubleshoot.As previously stated ,refer to your technician for possibilities he knows more about the machine than anyone on this forum,who have never seen your particular machine.
Re: Injection Molding Machine Clamping Position Varies
05/30/2019 9:18 AM
new scale is fine. also clamping open is working as per set parameter. clamp stop position read by system and physical is same. only problem is when closing.
now come to clamp setting parameter, is seems good as at same parameter we did well before(also check with changing in its low pressure and high pressure position to its minimum as 25 and 2 resp , which is not suitable generally but this will extend the time of error i.e clamp stop occurance . however its not full solution. our technician is looking at but we will now go further if problem will not resolve.
thanks for each comment.
05/30/2019 10:41 AM
What type actuator?Hydraulic,pneumatic,electric,servo?Full information will give better answers.Pictures,schematics,etc?
Here is a link that may help you.It covers similar problems:
https://www.sensorprod.com/news/articles/2009-04_pt/pr_pt-2009-04.pdf
05/30/2019 12:43 PM
Do you have the manuals?
Have you read the manuals, specifically the troubleshooting section?
Have you called customer service of the company that built the machine for assistance?
Have you gone on-line to search for similar machine problems?
Why do you withhold the make and model of the machine from the forum?
As HTRN said, have you asked the operator if they have any ideas?
In my experience, if it can't be rectified in less than a day, call a service tech. It will save you money in the long run, because if the machine is down you're losing money.
05/31/2019 9:50 AM
Sounds like poor setting of clamping system on machine.
Toggles not fully cycled and locked. (If it's a toggle clamp machine)
You might have a broken or loose machine tie bar, meaning that the machine is actually bending open during cycle.
You might simply have air in the hydraulic system (for both hydraulic or toggle clamp)
You might have a bent tie bar (or two) so that friction stops the machine reaching clamp setting before actual distance. Cuts out on pressure rather than stroke.
You might have pressure threshold set too low for "close" sequence and that trips before the "clamp" settings come into play.
You could have flash/material caught inside tool from previous short cycle that is holding tool open.
You might be exceeding your hydraulic pump capacity by the "requested" speed and stopping on "time" rather than pressure.
Your machine might be injecting "Hunt closed" before the tool is closed.
Your tool might be loose in the clamps and then material between fixed platen and fixed half of tool.
Etc. Your technician should be able to work though these.
Add a few seconds to the closing time and see what happens.
06/02/2019 10:16 AM
As this error is random we are running the machine and observe the situation.
Planning to fill hydraulic oil to main tank (observe it's level is middle of gauge).
Suggest how to remove air from hydraulic system (clamp valve assembly manifold)
06/02/2019 1:11 PM
Ranjan, you seem to miss important advice given on this forum. There is nothing wrong with the oil. Stop Micky mouse around. That machine should not move the barrel forward and apply pressure to the fixed mould if the clamping force was not reached. It will shear the fix mould retaining bolds right off. That machine should not inject material into a mould that is not closed except if the setting is so random that the program are totally confused. There are safety interlocks that are inoperative or tampered with. Get professional help and get production going. You are wasting your company resources.
06/02/2019 1:47 PM
I appreciate your comments.but still not points towards problem source.
Will look for professional help
06/02/2019 2:54 PM
We asked, but you did not have the courtesy to tell us the make and model of the machine you want advice on. We do point to the problem and advised you to get help. You are beyond your knowledge and need help. The problem can be multiple, settings, faulty transducers, lose or unequal stresses on tie bars, interlock bearings, mould hight adjustment, pump pressure. Worst of all is that some security device was tampered with and is overridden and that is the reason you get injection with a mould that is not fully closed and under pressure. Please let us know what happen next.
06/03/2019 1:48 AM
Machine model TRX850 having 4 servo motor.
It's have toggle type clamping.
Linear potentiometer model LPH 900 D 10K
I checked with clamp tie bar alingmenment is ok and any mechanical issues not find.
Any other information you need kindly let me know.
06/03/2019 2:59 AM
Since many people have now attempted to solve this issue, it's good to hear that you are getting a professional to come and assist you to resolve the issue.
One "way out these" problem that I saw once was when a technician changed a machine from metric to imperial. The machine was doing multiple "strange" things within the cycle.
Fortunately we had back-up files for the running settings for each tool. Once the machine was reset and re-calibrated all was good again.
Do you have software back-up of the necessary programs and files? Your visiting technician will probably want something like that to be able to confirm his work.
HiTekRedNek (2); Just an Engineer (2); lyn (1); Oomborrie (3); PWSlack (1); ranjan (4)
