Previous in Forum: Piston pump   Next in Forum: Vapor-Phase Oven
pneumatic pipe line problum retified soluction
10/14/2007 2:54 AM
1.How is retified pneumatic prussor drop, back prussor , leakage
Good Answers: 19
Re: pneumatic pipe line problum retified soluction
10/14/2007 4:04 AM
You do me "pressure", i hope else, please specify what is "prussor".
If its pressure drop, the only way to retify is to decrease volicity by increasing pipe size which as become undersized. Install a pilot operated pressure reducing valve (PRV)like the Spirax DP17 or Bailey G$ or Yoshitake 2000 to sense downstream and maintain pre-set pressure if up steam fluctuates and vice versa a back pressure PRV to sence the back presuure and maintain down stream. If it is back pressure only than a non retirn valves safeguards.If leakage plug it.
Good Answers: 19
10/15/2007 3:25 AM
Apology for not going through spell-check
You do mean "pressure" I hope else, please specify what is "prussor".
If its pressure drop, the only way to rectify is to decrease velocity by increasing pipe size which has become undersized. Install a pilot-operated Pressure Reducing Valve (PRV)like the Spirax DP17 or Bailey G4 or Yoshitake Model: 2000 to sense downstream and maintain pre-set pressure if up steam pressure fluctuates and vice versa a back pressure PRV to sense the back pressure and maintain down stream. If it is back pressure only than a non return valves safeguards against any back pressure where 2 or Compressors working in parallel. If leakage check with Ultrasonic Leak Detector or carry out soap-test and for God's sake plug it.
10/15/2007 11:33 AM
Get a plumber!!!!
Good Answers: 19
10/16/2007 12:36 AM
plummer rhymes with "prussor".
