Previous in Forum: Stator Test Results   Next in Forum: Frame Size of Electrical Motors
Greasing Method for Ball Bearings
06/13/2019 7:54 AM
Dear Gents,
kindly need your support, as some low voltage motors with bearing number 6317/C3 and other numbers has only greasing nibble for inlet, and there’s no drain nibble to remove the old grease while doing re greasing, and on the other way some motors has greasing nibble for both inlet and outlet,
So our questions are
  1. During re greasing for bearings, it is preferred to do it while motor is running or in stop condition, also in motors with drain nibble, do we have to open drain until filling the proper quantity of grease or what is the purpose of this nibble
  2. For motors which has no greasing outlet, what we have to do during re greasing, and where the old grease is going if we don’t have outlet port
Please advise
5
Re: Greasing Method for Ball Bearings
06/13/2019 9:27 AM
..."To calculate grease quantity, you need the bearing’s physical dimensions (primarily the outside diameter and width). Once you have these two measurements (in inches), you multiply them together and then multiply by 0.114. The resulting answer is the grease quantity in ounces. This formula can be used with metric measurements as well; just use 0.005 instead of 0.114. The result will be grease quantity in grams. This formula works for all bearings and is widely accepted as the best way to calculate grease quantity.
Once the required grease volume has been calculated, you will need to determine how often to apply that amount of grease. This timeframe is known as the regreasing frequency. This calculation is more complex. The machine’s operating conditions must be collected along with some additional bearing information.
Temperature is known to affect both grease and oil, so naturally one of the first correcting factors that must be collected is operating temperature. The hotter the environment, the more frequently the grease must be replenished. The ambient contamination (how dusty the environment is) and moisture (how humid the environment is) work in a similar manner. The dirtier and wetter the environment, the more often the bearing must be regreased.
Simple things like the bearing’s physical position and vibration will also affect the grease’s run-out and frequency of reapplication. If the bearing is mounted on a vertical shaft, the grease has a tendency to run out of the bearing quicker, thus needing to be replenished more often. When the bearing is subjected to vibration, it causes the oil in the grease to separate from the thickener, allowing it to drain away from where it is needed much faster. Therefore, these two correcting factors — position and vibration — should be taken into consideration.
The final correcting factor is that of the bearing element shape. This is important because each different element stresses the grease differently. For instance, a ball rolling across the race churns the grease differently than a spherical element, which churns the grease much more heavily.
Below is a chart of these correcting factors and how they operate together. Once they have been calculated properly, the final pieces of the puzzle are the bearing ID and speed of rotation. Through some simple math, you are left with a run-time (in hours) frequency for regreasing.
https://www.machinerylubrication.com/Read/29620/grease-quantity-frequency
Reply Good Answer (Score 5)
06/14/2019 7:58 AM
GA for the analytical approach though "That one needs a bit; this one a bit more; that one looks OK" is likely to prevail...
06/13/2019 3:58 PM
If the motor has a drain plug under the bearing remove it and grease the motor while running.Inject the grease slowly.Leave the plug out for 30 minutes with motor running after applying grease to allow excess to leave the bearing.Too much grease will causes the grease to churn,overheat and carbonize,causing premature bearing/and or motor failure.If there is no drain plug,normally the bearings are permanently lubricated.Forcing grease into a sealed or shielded bearing will destroy the seals,and escape past the seals/shields and into the motor stator.I have seen this many times.The grease does not usually harm the stator,unless really excessive and carbonizes onto the stator. But It does make a mess when rebuilding the motor.Apply grease until all old grease has escaped the drain plug by observing the color of the grease.
06/13/2019 4:10 PM
Does the bearing have any suffix numbers,like RS,2RS KD,KDD, ZR, 2ZR?These suffixes indicate if the bearing is sealed,double sealed,shielded,single shield,double shield.There are other suffixes according to the manufacturer of the bearing.I have only listed a few.
If there is no suffix, except C3(which is a clearance designation),it is an open face bearing;no seals no shields.If that is the case,you should consider drilling and tapping a grease drain hole if it has a grease nipple,or use a permanently sealed bearing as a replacement,and plugging the grease nipple hole.
HiTekRedNek (2); PWSlack (1); SolarEagle (1)
