Previous in Forum: Electron-Behaving Nanoparticles Rock Current Understanding of Matter   Next in Forum: Inductance Boost of a Flat Planar Coil Using Ferrite
Harmonic Test Error
06/24/2019 2:33 AM
While trying to conduct a Harmonic Analysis in (ETAP 16.0.0) for a grid model I have built , it could not be conducted as this message “ Calculation Process in OLV1 timed out” kept on showing up.
I changed the default time out of Harmonic test from (60) to different values but a new Calculation Error appeared ‘’ Harmonic calculation aborted due to numerical overflow/underflow problems ‘’ . And no matter I change the time out, the error couldn't be fixed. So What do you think ?
Re: Harmonic Test error
06/24/2019 3:02 AM
Clearly, the program couldn't cope with the information that had been supplied to it. So the natural thing to do is to revalidate the input information before proceeding further; if the input conditions cannot be made to work, then there is something fundamentally wrong with them.
If that doesn't work then there are three further courses of action available:
  1. Read the manual
  2. Telephone the program vendor for advice
  3. Get someone else to do the work, someone more experienced.
Good Answers: 128
07/05/2019 8:05 PM
Beyond what PWSlack has said, it is entirely possible that an undiscovered software programming error is involved. If that is the case, then ETAP may want to get a copy of your data set the program was working on. So the suggestion #2 is very reasonable.
--JMM
Re: Harmonic Test Error
06/24/2019 9:12 AM
07/09/2019 8:24 AM
Amazing software!
Register to Reply 4 comments
jmueller (1); msbettyhunt (1); PWSlack (1); SolarEagle (1)
