Previous in Forum: BN Accelerometer Probe Configuration Issue   Next in Forum: Nitrogen Gas Detector
TCP Port 502
07/04/2019 8:09 AM
Hey All,
I have fixed a gsm modem to a pumps controller and want to connect wirelessly to the scada software using the public IP address! but seems port 502 is not opened, any one can help how to make the port available from public ip address to my pc where scada is running?
Re: TCP port 502
07/04/2019 9:12 AM
<...any one can help...>
May one assume those at the <...gsm modem...> manufacturer's technical helpline are at lunch and therefore unavailable?
Re: TCP port 502
07/04/2019 1:18 PM
Probably a driver problem....
https://support.microsoft.com/en-us/help/10741/windows-fix-network-connection-issues
..."It mainly attributes to a lack of network adapter driver, the driver is outdated or it's incompatible with the system. "...
https://www.iobit.com/en/knowledge-how-to-fix-network-adapter-driver-issue-on-windows-14.php
Re: TCP Port 502
07/05/2019 8:45 AM
First, let me warn that connecting an industrial control system across a public internet is not a good idea. It allows anyone who has the urge to access your pump controller, perhaps even your whole SCADA system.
If your SCADA system is setup to have secure access you will also have to program one or more firewalls to allow the communication a path to your PC.
GSM is a proprietary GE protocol that is only similar to TCP/IP. You may have to use a translation program to convert it back to TCP/IP.
Re: TCP Port 502
07/05/2019 10:23 AM
Good Answers: 19
Re: TCP Port 502
07/05/2019 12:36 PM
Port 502 is the typical default port for Modbus/TCP communications. I suspect that Windows Firewall, or any other firewall has disabled port 502 by default.
The warning about connecting over the internet to an open port is real. You need to be using a VPN.
Re: TCP Port 502
07/09/2019 7:28 AM
Thanks Bud, but do you have any topics I can find about this? structure or illustration?
Re: TCP Port 502
07/09/2019 7:27 AM
Thanks All,
To open 502 port first you need to open it from router, then using following command at the local host to open it between router to local hos:
netsh interface portproxy add v4tov4 listenport=130 listenaddress=192.168.1.116 connectport=223 connectaddress=192.168.1.203
Replace the "listenport" and "connectport" numbers with the source and destination port numbers, and replace the "listenaddress" and "connectaddress" numbers with the source and destination IP addresses.
Register to Reply 7 comments
Bud (1); Fardan (2); PWSlack (1); SolarEagle (2); XNuke (1)
