Previous in Forum: What Is This Tool?   Next in Forum: Sewer Line Insurance
Diameter Needed for Spindle Extension
07/07/2019 2:16 AM
Dear Sirs,
Would like some of your opinion regarding what size of Spindle extension to use for DN1200 Butterfly valve with Torque of 20,000 Nm. Spindle length is around 10 meters. With gearbox on top with 30,000 Nm. We like to use Monel 400 for the material of spindle. Can you recommend what is the diameter should we use for this application? By the way valve is totally submerged in water @ around 8 meters deep.
Good Answers: 137
Re: Diamater needed for spindle extension
07/07/2019 5:42 AM
What are shaft diameters of the valve and gearbox output? That would be a good starting point, though these will be steel so need to check allowable shear stress of Monel 400. Also check torsional deflection as this might be significant if there are limit switches etc involved.
Re: Diameter Needed for Spindle Extension
07/07/2019 8:46 AM
What is the size of the butterfly valve?
What is the application environment?
What is the velocity and composition of the fluid through the valve?
Is this a triple-offset butterfly valve?
Much more information is needed to help you.
As a last resort,of course,contact the manufacturer of the valve.(Hmmm!Why didn't I think of that?)
07/07/2019 11:48 AM
07/08/2019 3:52 AM
This is the sort of challenge that needs to be asked of the friendly local Valve Distributor. Telephone?
07/08/2019 8:27 AM
...because the Valve Distributor will give more than an <...opinion...>; it will give a "quotation" and, on purchase, a "warranty" and "after-sales service". That's what it is there for.
07/16/2019 9:25 PM
Where:
D is the shaft diameter
P is the rated horsepower
S.F. is the safety factor chosen
S is the yield strength in torsion
N is the shaft rpm
321,000 is a factor derived from converting horsepower to torque/balancing units
Note the yield strength in torsion is a calculated value from the tensile yield strength according to ABYC P6.
http://www.wbmetals.com/shafting.asp
07/16/2019 10:03 PM
There are three strength criteria of interest:
1. Ultimate shear--will the shaft break?
2. Yield (plastic) shear--will the shaft twist enough to take on a permanent incorrect set?
3. Elastic shear--will the shaft twist enough to affect angular indication at the far end?
Codemaster's post reflects 1 and 3; Solar Eagle's reflects 2.
Register to Reply 7 comments
Codemaster (1); HiTekRedNek (1); PWSlack (2); SolarEagle (2); Tornado (1)
