Does anyone know how to pair Nokia 6086 (T-mobile) blue tooth on Toyota RAV4 since its newer phone software version from the one recommended by Toyota as Nokia 6133
I did use the car's manual for the Blue Tooth pairing and the cell phone user manual, and as soon as the cars verbal request for "name the phone" it follow immediately with the word "cancel". So that makes me to believe that something that I do is not correct, do you know?
Copy me the relevant pages out of BOTH manuals in something like .jpeg or .bmp format, make sure they are fully readable, send me an email on the CR4 email system and I will send you my normal email address, send me the pages...I will do my best for you....
So I have looked at the Nokia manual for your phone and I believe the following is what you need to do, or very close. Let me know what or where it fails (if it does!):-
(By the way, these things time out so you have to be fairly quick and be sitting in the car etc before starting. Keep to my logical progression)
On the phone (See page 66 in the English Nokia Manual)
Select menu >
Settings > connectivity > Bluetooth
Select Bluetooth > On
In
the Car
Push the voice command button and wait for a beep (wait for a beep
before issuing a voice command at each step)
Say "Setup"
Wait for
Beep
Say "Phone setup"
Wait for Beep
Say "Pair phone"
On the
phone
Select Search for Audio Enhancements
Select Paired Devices (this is different to my Nokia and is not clear in the manual. This is perhaps where the problem lies....)
Select New
Scroll to the required device (Toyota car!) and select Pair
If a
passcode is given for you car, enter this passcode into the phone, you may have
to get this from the car manual if it is not displayed on a screen in the car. Usually a number, but can be anything....
You only need to enter the passcode the
first time a connection is made between devces, it should never be needed again unless someone removes the battery from the car or similar. Keep a note of it "just in case".
I hope this helps......
