Previous in Forum: Blue tooth pairing   Next in Forum: jammers
India - Member - Sudhindra
Definition of Noise Margin?
10/18/2007 8:23 AM
Can anyone please explain me what exactly 'noise margin' is?
Re: Noise Margin
10/18/2007 8:40 AM
Re: Noise Margin
10/18/2007 9:12 AM
i don't know the exact answer.from my view it is the external thing that is added to the input which does not cause any undesirable changes at the output........
Re: Noise Margin
10/18/2007 12:55 PM
That's a nice simple definition...
I was going to ask 'In what context' ...but your reply works independant of context.
I doff my cattly hat!
Re: Definition of Noise Margin?
10/21/2007 9:45 PM
its a difficult problem. different system has different noise margin.
however, if there is esisting a very little you adoptable, recievable, comprehensvable informaiton means the least margin of noise.
India - Member - moorthi
10/23/2007 1:49 AM
In digital logic, signal presence is marked as 5v dc ( or logic "1"). Same way no signal is marked as zero voltage ( or logic "0"). All logic circuits accepts logic 1 if voltage >3.5v DC. logic zero if voltage <2.5vDc. so voltage level between 2.5 to 3.5 is called noise margin. In this region ,we can't say signal is logic 1 or 0. Here voltage level < 2.5v and > 3.5v is explanation only not exactly correct, you refer your data sheet of particular IC.
10/24/2007 7:23 AM
Im afraid your example is not very right.( sorry for my comment)
generally speaking noise signal is not equal to undetermination zone signal.
Register to Reply 6 comments
Anonymous Poster (1); cnpower (2); moorthi (1); sundaramoorthy (1); user-deleted-1105 (1)
You might be interested in: Noise Standards, RF Noise Meters
