Previous in Forum: Using Stainless Steel Grub Screws in 4140 Alloy   Next in Forum: PVC Pipe Making Ratio
10 comments
Sulphonic acid NP9 Pine Oil
07/20/2019 3:00 PM
Can one form a clear and stable gel with the following
Sulphonic acid
Pine oil
NP9
How do you go about mixing them
Re: Sulphonic acid NP9 Pine Oil
07/20/2019 3:12 PM
Quantities, temperatures and pressures would be a good start!
Please help the forum provide assistance by listing those things that have been tried and found not to work?
Please explain the term <...NP9...>?
07/20/2019 6:51 PM
07/21/2019 1:52 PM
Nonylphenol Ethoxylate. That's NP9
07/22/2019 4:06 AM
The Original Poster would have saved time by stating that to the forum in the original post.
"Some mothers do 'ave 'em..."
07/20/2019 3:38 PM
Safety Information
Symbol GHS05, GHS07, GHS09 Signal word Danger Hazard statements H302 + H332-H318-H411 Precautionary statements P273-P280-P305 + P351 + P338
Personal Protective Equipment Eyeshields, Gloves, type N95 (US), type P1 (EN143) respirator filter
If you don't know how to do it, you probably should not try it.
07/20/2019 7:34 PM
Good Answers: 92
07/20/2019 10:56 PM
Yes you can.
By mixing carefully. Sulphonic acid will react with most terpenes, as I can tell from experience (a straight mixture with d'Limonene will melt a PVC bottle and emit plenty of smoke that smells worse than putting your nose over the exhaust of a poorly running diesel).
By the way, what are you using to neutralize the sulphonic acid? And what viscosity range of gel is desired? The nonylphenol has its own gel range, and you haven't detailed if this mixture is to be water or solvent based (it could be either!). Provide more info and you'll get more advice.
07/21/2019 1:54 PM
It is water based, neutralizing it with sodium hydroxide
Good Answers: 92
07/21/2019 3:39 PM
Okay.
The simple fact is that you are trying to create a microemulsion if you want it to be clear. The branched DDBSA, especially neutralized with isopropylamine (Rhodacal IPAM was a product I used to use) are far better for this than sodium LABSA, but the cost is much higher. The other point is that in my experience the break point from a normal emulsion to a microemulsion is typically accompanied by a reduction in viscosity, which is not what you want.
My recommended mixing procedure, based on typical double distilled pine oil (try small quantities first!) and assuming you don't want to use any other ingredients:
  1. Premix the pine oil and NP9. This will thin out the NP9 and dilute the pine oil to reduce runaway polymerization.
  2. Add the sulphonic acid, mixing well. DO NOT HEAT!
  3. Add to the water with agitation.
  4. Add NaOH as desired to neutralize.
You will have to experiment with the proportions of each to achieve the desired result, and have a fairly high percentage of NP9 to gel the product (note that different manufacturers often have different gel curves due to ethoxylation variations, which can be obtained from their literature). It may be more economical and efficient to use a carbomer, polyacrylate or gum to thicken instead.
07/22/2019 7:13 AM
This is really helpful.
JNB (2); lyn (1); msbettyhunt (1); Mwaba (2); PWSlack (2); Rixter (1); SolarEagle (1)
