Previous in Forum: Sulphonic acid NP9 Pine Oil   Next in Forum: Cartridge Heater Failure
10 comments
PVC Pipe Making Ratio
07/23/2019 4:03 AM
What is the Stabilizer And other chemical ratio for make u-PVC pipe making.If there are we want to use 100kg Resin a batch.
Re: PVC Pipe Making Ratio
07/23/2019 7:17 AM
Is that information commercially sensitive, perhaps?
07/23/2019 8:46 AM
Yes sir that is commercially
Thanks to you
Zihad
07/23/2019 9:05 AM
... then Anonymous Poster#1 is not likely to receive an answer to the original question.
07/23/2019 11:38 AM
..."There is only one difference between PVC and uPVC and that is that PVC contains BPA and phthalates, which are two plasticizers that make it more flexible. The "u" in uPVC stands for "unplasticized," and because it doesn't have these extra materials, uPVC is often called rigid plastic."...
https://www.hunker.com/12363307/the-differences-between-upvc-pvc-pipes
http://www.plastemart.com/plastic-technical-articles/Essential-Compounding-Chemicals-used-with-PVC-Resin/1602
https://www.hanserpublications.com/SampleChapters/9781569905432_9781569905449%20PVC%20Additives%20Schiller%20SAMPLE%20PAGES.pdf
07/25/2019 8:52 AM
If the uPVC is rigid plastics then the chances of getting cracks would be more than normal plastic... Is that still safe to use?
07/25/2019 9:54 AM
Commercial <...rigid...uPVC...> pipe is widely used. Many organisations use it with complete safety however its application needs to be considered carefully in light of the particular circumstances of use. Many organisations have adopted it as a standard.
Plastics are widely applicable as piping systems where metals would not survive the experience.
07/26/2019 9:17 AM
Yes, Plastics are good options.
Good Answers: 137
08/06/2019 3:47 AM
But never for compressed gases.
07/23/2019 3:17 PM
You'd need to ask the resin manufacturer this question.
08/20/2019 2:52 AM
Thanks, Iyn!
Reply Off Topic (Score 6)
Codemaster (1); lyn (1); msbettyhunt (3); PWSlack (3); SolarEagle (1); zihad (1)
