Why can't we plot our precise location in the universe with respect to the precise location of the Big Bang by plotting our position, velocity, lateral acceleration and angle of trajectory relative to adjacent and distant stars and galaxies? This should help pinpoint the precise direction we would need to look in to see the actual Big Bang. Then we would need to turn Hubble on to that spot and we would see back in time wouldn't we? Granted maybe not to the first moments of BB but we should be able to see events that are still ongoing as part of the BB and that are younger than ourselves and of our immediate vicinity. If BB actually happened, that is. I guess Hubble is maybe not able to see that far back but at least if we knew precisely where to look Hubble might be able to pick up some clues as to the precise location and then later, more powerful scopes could hone in on the point if we got some clues as to where it is. The point I'm getting at is that with the BB being so far away, unless we start by plotting our known position with extreme precision we are not going to be able to find BB merely by scanning the skies because going that far back and considering the loss of accuracy that comes with even a thousandth of a degree of being off target over that kind of distance when you are dealing with angles, that could put us light years away from the spot. At least if we got the spot right we should be able to see stuff way back nearer the event because it should be moving faster because of its being nearer to the event.
