Previous in Forum: Backfilling in RRM Walls   Next in Forum: Column Pad
8 comments
Rebar Mesh Footing Details
08/12/2019 9:04 PM
Dear sirs,
Is it possible to have rebars of different centre to centre spacing say, 150mm and 250 mm on two sides of a footing in lower mesh and upper mesh?
Similarly, I think the top mesh rebars have lower rebar diameter than the lower rebar. Is it good to have rebars of same diameter?
Best Regards,
Re: Footing details
08/12/2019 9:30 PM
Re: Footing details
08/12/2019 9:45 PM
Re: Rebar Mesh Footing Details
08/12/2019 10:11 PM
Of course it's possible..
Have as many diameters and spacing variations as you wish.
Whether or not it's the best method is another question.
Reply Good Answer (Score 4)
08/15/2019 7:34 AM
Quite.
GA
08/13/2019 7:57 PM
It would be an issue of rebar surface area, assuming you do not want to mix in grades of steel as well...
It is theoretically possible to have more numerous smaller diameter rebar in one layer, and a lesser number of larger diameter rebar in the other layer, so that the two rebar layers affect the surrounding concrete nearly equally...
But from a practical, cost-saving, stand-point, it is more cost-effective to have only the minimum number of different rebar diameters on one job in order to get the largest cost-advantage in purchasing the largest amount of rebar for the lowest cost-per-rebar-diameter possible for the particular concrete construction job at hand...
Just follow the approved engineering detail and avoid confusing the inspector...
08/14/2019 12:00 AM
Plus, the shape and loading of the concrete will have some bearing on rebar use, assuming this question comes from observation of a structure in front of you. You may have offset or moment loading on the footing, surcharge on one side, seismic or uplift forces, any number of factors that the structural engineer considered when coming up with the design you see. With the limited data you have provided, it is difficult to even guess at the reinforcing design considerations.
08/14/2019 11:07 AM
There is no rule of thumb that relates the top reinforcement steel to the lower reinforcement steel. The only likley relation that I can think of off hand is the requirement for a minimum amount of reinforcement steel that is required for temperature steel.
The amount of steel in the top or bottom of the foundation depends on so many variables. These include tension stresses, compression stresses (these are all related to loading and the dimension of the foundation), concrete strength, thickness of the foundation, bearing material strength, etc.
If this is a foundation of consequence and you utilize a rule of thumb, you would be extremely foolish. If, however, this is a foundation for something like your deck or perhaps even a house, then the use of a standard detail or rule of thumb is probably acceptable. That said, most locals in the US require that foundation plans for inhabited structures be stamped by an engineer.
So please consider what you are supporting with the foundation before you prepare a foundation using some rules of thumb.
08/14/2019 11:10 AM
You can do almost anything but your thicker rebar mat is supposed to be on the bottom. The center spacing will be dictated by your specs if you are using double mat on significant loads.
I worked many concrete jobs and county requirements are very minimal and too minimal in my opinion. Federal/state requirements are much tougher and realistic.
I always say rebar is cheap insurance. Double or triple it if you can on home projects for footings. They had a pathetic 3" heel and toe footing on my 6 inch wide 3 foot wall that met county requirements. Now there is significant cracking. You cant easily go back and make it right.
ccoop609 (1); DinosaurDad (1); JE in Chicago (1); MR. Guest (1); PWSlack (1); rwilliams (1); SolarEagle (2)
