Previous in Forum: Generator Synchronization Problem   Next in Forum: 3P or 4P ACB in Outgoing Feeders for TN-S system
10 comments
How To Achieve High Ion Generation?
08/18/2019 1:39 AM
Is there a way to achieve a high ion generation? I am looking for ways to generate at least 5x10^20 ions/cm^3 . Is there a way to do that?
Pathfinder Tags: Ionisation
Re: How to achieve high ion generation ?
08/18/2019 7:14 AM
Increase emission points and increase voltage.
Nano size emitters will help,if you have enough of them.
Still,no guarantee you will reach your target.
08/18/2019 8:03 AM
..."About 3 X 10^22 air molecules in a cubic meter. A mole of any gas takes up 22.4 cubic meters, and contains 6.023 X 10 ^23 molecules. Divide the latter by the former to get molecules per cubic liter. For an exact answer, adjust for temperature and pressure, and use the values corrected to STP.Jul 31, 2017"...
https://www.quora.com/How-many-air-molecules-are-present-in-a-cubic-meter-of-air
What is it exactly that you are trying to do?
08/18/2019 10:23 AM
My aim is to make a plasma conductor in which plasma is made from electric field.
My aim is to conduct 8amps so for that i need atleast 5x10^20 ion pairs.
08/18/2019 2:25 PM
..." the unit of electric charge is amp seconds (ampsec, which is also called “coulomb”); its symbol is Q. One ampsec is the charge of 6.25×1018electrons or protons (ions). An amp is 6.25×1018 electrons/sec. Force is expressed in grams (technically gramweights)."...
https://www.alphalabinc.com/electrostatic-formulas/
..."You can do that by connecting a charge pump like a Van de Graaff generator or a Wimshurst machine to a large capacitor such as Leyden jar.
If you really do mean Amperes, then you can discharge the capacitor and release the charge in a short high-ampere burst. "...
https://forum.allaboutcircuits.com/threads/electrostatic-current.20153/
Good Answers: 137
08/18/2019 3:26 PM
I think you're a factor of 1000 out there. A gram-mole contains 6.023 X 1023 molecules. A kg-mole contains 6.023 X 1026 molecules.
Air has density (at NTP) 1.29 kg/m3. Molecular weight ~ 29. So number of molecules in 1 m3 = 1.29/29*6.023 X 1026 ~ 2.7*1025.
08/18/2019 4:38 PM
So this density of negative ions should be doable....?
https://scienceline.ucsb.edu/getkey.php?key=274
Good Answers: 137
08/18/2019 6:44 PM
I was just commenting on your post, but 2.7*1025 molecules/m3 = 2.7*1019 molecules/cm3, so 5*1020 ions/cm3 looks highly unlikely, more so if the plasma is hot. I've not heard of making a plasma from an electric field, as the OP says.
08/18/2019 6:55 PM
What if the temperature was close to absolute 0 ?
Good Answers: 137
08/19/2019 4:51 AM
That's likely isn't it? Happens all the time
Re: How To Achieve High Ion Generation?
08/18/2019 5:30 PM
Register to Reply 10 comments
Codemaster (3); HiTekRedNek (1); Jerinsam (1); SolarEagle (5)
