Previous in Forum: Calculating Open Circuit Voltage Across CT Terminals   Next in Forum: Looking for Email Contact of Matsusada Precision Inc.
17 comments
Earth Electrode Systems (BS 7430)
09/09/2019 5:47 PM
Hello
In the practical grounding guide BS7430 there are several methods for making a grounding
1. I have never seen these methods in practice, if anyone among you can share with me photos that show these methods. (like :Plates , Horizontal strip or round conductor electrodes , Parallel connection of aligned rods , Strip or round conductor electrodes , Mesh , Miscellaneous electrodes )
2.to calculate the ground value for a Rods or pipes there is the formula below
why in this formula they have not taken into consideration the resistance of the cable that connects the rods or pipes to the Main earth terminal ?
thank's
2.
Pathfinder Tags: BS 7430
Re: Earth Electrode Systems (BS 7430)
09/10/2019 3:22 AM
<...why...not taken into consideration the resistance of the cable that connects the rods or pipes to the Main earth terminal ?...>
Because that is taken into account in other testing that needs to be carried out in accordance with BS7671.
09/10/2019 9:35 AM
thank you
We need to know its value before the test, to verify that the residual current device chosen works well or not.
09/10/2019 10:06 AM
All the data that is needed for the calculation is independent of the cable.
A <..residual current device...> is mandatory for TT-earthed systems in many countries' standards. The resistance of the earth cable in TT is tiny in comparison with the electrode resistance and in practice can be disregarded when selecting the device.
Good Answers: 116
09/10/2019 8:51 AM
You must enter some realistic values into the formula, e.g. 100 Ω-m for resistivity of soil, 3 metre pipe of 0.05m diameter. That 100 ohm-m is e.g. a good moist soil suitable for growing crops, so many locations are much worse.
I think you will find a value of about 30 ohms. Compare resistance of 6 sq.mm copper ~ 2.9 milliohm/metre - so 100 m is 0.3 ohm.
Hence the connecting conductor resistance is negligible [except where there is a really big earth farm, substantial power stations specify 0.5 ohm] - in any case it would be included in resistance when earth resistance is measured properly. Usually the connection to earth system is sized by current carrying capacity & physical robustness rather than resistance. Examine a lightning conductor installation on a building.
67model
09/10/2019 9:48 AM
Yes, you are right. But in a project, the choice of residual current circuit breaker is made before the measurement of the resistance; we must calculate an approximate value of grounding to choose the right residual current circuit breaker.
09/10/2019 10:14 AM
In many cases the <...right residual current circuit breaker...> will be determined by local practices. 100mA is typical for a domestic TT here to protect the entire installation, such a value protecting against a "poor earth" with 30mA breakers downstream protecting individual circuits for personal protection under BS7671.
  • A residual current in excess of 100mA might suggest a serious safety risk with the installation, for this value, if it were passed through a human, can cause fibrillation, etc..
  • Individual circuits protected at 30mA are considered safe under the standard.
Information to the forum about <...a project...> might yield additional guidance.
Good Answers: 116
09/10/2019 11:55 AM
See post #6. You may deduce that ten times the 3m rod example of 30 ohm - a 300 ohm earth x 0.1 amp is only 30 V and a small part of a typical 230V supply - BS7671 gives a maximum value of 500 ohm earth loop impedance for a 100 mA non-delayed RCD, but notes that earth resistances over 200 ohms are unstable. A 100 mA RCD would be used on main incomer, but 30 mA on its distribution circuits for personnel protection.
Following has reference to helpful documents.
http://www.esgroundingsolutions.com/how-do-you-meet-a-grounding-system-requirement-for-0-5-ohm-earth-resistance-in-thailand/
Any approximate value could be a very wrong guess compared to a specific site. Values measured for known rods at existing sites nearby are better than speculation. Note that seasonal changes & weather year to year changes mean that measurements have to be made regularly.
09/10/2019 12:03 PM
...and a disturbingly large value may be reduced by tipping a large quantity of seawater over the earth electrode area.
Good Answers: 116
09/10/2019 4:17 PM
If the water is pure, it has very high resistivity - it is the dissolved minerals which make it conduct.
Given the typical minerals, about 12% water gets 100 ohm-metre. Below 10% water, resistivity increases rapidly.
see https://www.scribd.com/presentation/112775002/Earthing-system-design-Myths-Facts#download
So I guess if you get 1 kg of soil, heat it to drive off all moisture and it then weighs 0.9 kg, it has about 10% water content. But surface soil can be quite different to that at depth.
Banging in a test rod or few is probably easier than digging a hole [also easier than digging holes to bury earth plates]. Maybe you could test someone's existing rod to your own rod at several distances separation.
https://en.wikipedia.org/wiki/Soil_resistivity
Good Answers: 116
09/10/2019 5:08 PM
At points outside the earth grid, the potential rise decreases. The simplest case of the potential at a distance is the analysis of a driven rod electrode in homogeneous earth carrying I amps. The voltage profile is is inversely proportional to radial distance r rom rod given by the equation in Wikipedia.... V = ρ x I/(2 x 3.142 x r)
https://en.wikipedia.org/wiki/Earth_potential_rise
If the current I comes from another rod at a distance, so there is a length of uniform potential between them, this can be taken as the earth potential & voltage at various distances rx from rod examined for conformity with inverse law.
09/11/2019 10:59 AM
Thank you PWSlack
Good Answers: 116
09/10/2019 10:41 AM
This may be useful.....
09/11/2019 10:58 AM
thank you very much 67 model
09/11/2019 12:11 PM
This is how not to do it.
09/12/2019 1:18 AM
Got my ‘earth’ connection, what else could you ask?
Good Answers: 42
09/11/2019 12:15 PM
See-for instance:
ERITECH Grounding Products and Systems
https://stevenengineering.com/Tech_Support/PDFs/ERICO_GROUNDING-BONDING.pdf
in order to see the earthing [grounding] products.
Since the earth resistance is very high with respect to copper [or aluminum or steel] the connection and the electrode itself resistance may be neglected.
Julius
09/12/2019 8:13 AM
Thank you 7anoter4
Register to Reply 17 comments
67model (5); 7anoter4 (1); Amineln (5); PWSlack (4); rwilliams (1); StandardsGuy (1)
