Previous in Forum: Solar Night Lamp Problem   Next in Forum: Busbar Sectionalizing Isolators
Electrical Routine Test Requirement on MV CONNEX Insulating part
09/19/2019 4:08 AM
Our contractor procured Plug-in dry type termination kit from a well known manufacturer for 33kV Cable accessories, while asking about Electrical Routine Test certificate, the manufacturer has sent a declaration that, "Electrical Routine Tests on the Main Insulation of MV CONNEX cable connectors is not required in the standard DIN VDE 0278-629-1 resp. IEC60502-4".
I have no idea whether the statement given here referring IEC/VDE is correct.
If you can please guide me on this.
Re: Electrical Routine Test Requirement on MV CONNEX Insulating part
09/23/2019 7:09 AM
Why is it wrong, then?
Is compliance with the standard a contractual requirement?
