Is the maximum torque exerted by electrical or pneumatic operator that valves can withstand depends on the valve class. For example a pneumatic operator that fits class 300 ball valve of 24" and rating of 740 psig will only produce a maximum torque to enable closing the valve with the maximum differential pressure which is 740 psig. If not what are the precautions needed when fitting a manual vale with electrical or pneumatic operator
