Previous in Forum: Sourcing High Lithium Aluminium   Next in Forum: What Is It? I Haven't a Clue
10 comments
Electric Airplanes
10/09/2019 12:54 PM
..."Developing electrical propulsion to the sort of levels that could power electric aircraft is a tricky undertaking. Weight is a key consideration and directly relates to how far an electric aircraft can travel. As such, MagniX has developed a motor that does without standard components like cooling equipment and a speed reduction gearbox, enabling it to travel light.
Instead, its magni500 motor uses a closed-loop liquid cooling system and turns at 1,900 rpm, which CEO Roei Ganzarski says allows for direct drive to the propellor. The motor delivers 750 hp (560 kW) and more than 2,800 Nm (2,065 lb-ft) of torque."...
Motor ~ 300lbs
https://newatlas.com/aircraft/magnixs-750-hp-electric-motor-first-propellor/
https://www.magnix.aero/products/
Re: Electric Airplanes
10/09/2019 1:13 PM
Weight is certainly a critical concern with any aircraft. The weight and cooling of an electric motor seem like a trivial problem. The weight of the stored electric power (batteries) would be my concern for the crux of the problem. The Solar Impulse mitigated the battery needs by gathering solar energy during flight.
10/09/2019 4:00 PM
Trade engine/drivetrain mass for power storage battery mass...and...augment with solar panel *coatings* on ALL surfaces except bottom.
10/09/2019 8:52 PM
..you can still put solar panels on the bottom of the top wing and mirrors on the top of the bottom. If biplane.
10/09/2019 11:35 PM
The problem is they produce very little in the way of power compared to the power demands of the engines. All well and good for light weight aircraft (practically gliders) with massive surface area and little cargo weight, but still impractical for aircraft carrying any decent weight (like passenger or cargo aircraft).
Someone is going to have to come up with a decent advance in high energy density, light weight electric power cells to really make this practical for anything other than specialty electric motor aircraft. We may have to wait a while still.
10/10/2019 12:51 AM
10/10/2019 1:11 AM
10/13/2019 12:15 AM
10/10/2019 1:22 AM
10/11/2019 1:19 PM
Notice the date of that article, 3 years ago. What's the state-of-affairs currently?
10/11/2019 1:45 PM
Still waiting for air taxi's to become a thing I guess.....Licensing, certification, logistics, support, probably all of these and more....There seems to be no news, maybe they ran out of money....that would be my guess...
Register to Reply 10 comments
70AARCuda (2); jack of all trades (1); JE in Chicago (1); redfred (1); SolarEagle (5)
