Previous in Forum: Drainage Quote   Next in Forum: Transformer Foundation Drawing
18 comments
Question
10/20/2019 3:45 PM
I was involved in a single vehicle accident yesterday. I feel banged up. I want to find out force of impact. I felt ok for the most part at first, but by the time our car and us got towed to our house, I knew I got hit hard. I laid down, but pain increased. I went to urgent Care, nothing broken according to x Ray's. Now I feel all out of alignment. My husband and I were traveling at 35 mph on a slight down grade highway when a curve caused our vehicle to start spinning. I was on the passenger side, which hit the embankment/hillside suddenly stopping after doing a 360 degree spin. Both tires on the passenger side deflated. Does anyone know the force of impact in this case?
Re: Question
10/20/2019 4:18 PM
F = m * v² / (2 * d) ,
  1. F is the average impact force,
  2. m is the mass of an object,
  3. v is the initial speed of an object,
  4. d is the distance traveled during collision.
I'm afraid you would need exact measurements to get an accurate answer, and without scientific instrumentation in place, the best you can do is estimate....
https://www.omnicalculator.com/physics/car-crash-force
At 35 mph, and with all the cushioning built in to an automobile and the surface you contacted, it's likely you will just be stiff for a few days....but to be safe you should get x-rays and a doctors' opinion and check back after a week...Your age and weight, general muscle tone, tightness of seatbelt, if you were wearing one, all these things and more come into play...
Re: Question
10/20/2019 10:36 PM
Thank you for the formula!
Re: Question
10/20/2019 10:37 PM
Thank you for the link too.
Good Answers: 27
Re: Question
10/21/2019 8:18 AM
I believe the car coming from a linear motion, doing a 360 may involved some transition from linear to angular momentum, which may possibly be a much stronger force just before it hit the embankment and stopped.
just a thought..
vsar
Good Answers: 145
Re: Question
10/23/2019 7:19 AM
There are many answers to your question and none are exact without exact numbers to use in SolarEagles equation.
When you first look at the equation you probably think of the speed and mass of the car. That takes you down the path toward one answer.
There actually were many crashes the day of "the crash". The car was stopped by whatever it crashed into. Your torso was stopped in a different distance and a different amount of time by whatever you hit (or were restrained by) inside your car. Your head has a hinge called the neck and it was stopped in a different distance and a different amount of time and therefore the forces on it were different. Your heart, lungs, brain and other organs are sloshing around in a meat and jelly container called the human body. All of them stopped differently.
The car was spinning so in some cases the torque (twist) may have been a more significant issue than the forward component of the impact.
If you think about it the many parts of your body that can move and many parts of the car stopped in different distances and different amounts of time during "the crash". If you had fine enough instrumentation there are thousands of different answers to your question. Even a millisecond of difference can be significant when you are involved in the rapid disassembly of a car.
Re: Question
10/20/2019 4:51 PM
What type of car does a 360° spin traveling down a slight grade with a curve?
Also.. what type of tire? Does someone overinflate the tires to increase mileage?
The impact would be like jumping into your car ...from the roof of the garage.
Agree with SE. These injuries will slow you down for a few days, aggravate you for a few weeks, and remind you for a few months.
Glad it's only tires that popped.
Re: Question
10/20/2019 10:44 PM
One traveling on a wet road ten to fifteen miles over the speed limit with little tread left on the tires. You are right, I am glad the tires is all that popped.
Re: Question
10/21/2019 2:54 AM
Speed limits are there for a reason. Looks like the reason has been discovered.
Re: Question
10/21/2019 7:14 AM
There is a reason for tread being on the tyres/tires. Looks like the reason for that has been discovered...
Re: Question
10/20/2019 8:36 PM
The short answer is, with the information provided, no one can calculate the forces involved, and how those forces were transferred to your body.
"Traveling at 35 mph on a slight down grade highway when a curve caused our vehicle to start spinning" seems totally illogical. There must be more to the story.
You give no indication as to the conditions of the road, your vehicle and tires.
Any informed answer would only come with much more information.
Consult your insurance carrier.
Re: Question
10/21/2019 4:53 AM
The force doesn't matter so much as how and where it was applied.
Falling 4' can kill you, while people have survived falling from a 6 storey window onto tarmac.
Good Answers: 15
Re: Question
10/21/2019 5:57 AM
Not sure what year your car is or if you want the insurance company involved. But I believe modern day cars have a so called black box in them that will show just about everything you are asking for. The insurance company may not be willing to give you the info even if you ask nicely.
There may even be a way not involving the insurance company to get the info.
scotchdrnkr
Re: Question
10/21/2019 7:15 AM
Hurrah for crumple zones!
Re: Question
10/21/2019 7:17 AM
Will the incident appear on one of those car crash videos on YouTube?
Re: Question
10/21/2019 7:18 AM
It's a good job no other road user became <...out of alignment...>.
Re: Question
10/21/2019 10:01 AM
Knowing the force of impact won't help you. If you are out of alignment you should see a chiropractor, or a masseuse might do.
Re: Question
10/23/2019 2:34 PM
Agreed, a quick checkup with a chiropractor may be all that is needed if it is a simple misalignment issue caused by the accident. A hospital visit won't pick this up.
Re: Question
10/21/2019 11:41 AM
First, go back to the doctor and insist on a more thorough examination. If you felt delayed pain, find out the medical reason, as soon as ou can...
Register to Reply 18 comments
BruceFlorida (1); EMARK100 (3); jack of all trades (1); JE in Chicago (1); lyn (1); MR. Guest (1); PWSlack (5); scotchdrnkr (1); SolarEagle (1); StandardsGuy (1); user-deleted-1105 (1); vsar (1)
